May 14, 2006 - 3:35 AM
Enthusiast ![]() ![]() ![]() Joined Feb 20, '04 From Washington Currently Offline Reputation: 0 (0%) |
Here is the deal. Everything is wirered up correctly, we checked every single pin out and its all good. However, after the engine fires is does not keep running. It starts and then quickly dies. We checked the injectors and they are not grounding properly to inject fuel. So is this an ECU problem??? If any of your 4age guys have any idea PLEASE let me know. -------------------- |
May 14, 2006 - 4:24 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
The injectors aren't firing? Are you sure? Do you have any codes? What does your engine bay look like right now? Are the ECU ground wires (the brown ones) grounded good?
-Doc This post has been edited by Dr_Tweak: May 14, 2006 - 4:30 PM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
May 15, 2006 - 11:11 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
is your fuel pump priming?? when you turn the key ?
-------------------- yea your 3sgte is cool but ill stick to my 7agte
May 15, 2006 - 2:52 PM
nik you nailed it!
It was the fuel pump. For some reason the B+ battery was not getting to it. So we hooked it to the battery yesterday and it ran!!! Its so close to being done I can smell it!! I'm starting to get really excited! -------------------- |
May 15, 2006 - 3:14 PM
gald you got her running hey you should come to the Tri-cities meet that coming up
| Lo-Fi Version | Time is now: September 3rd, 2026 - 10:05 PM |
