May 14, 2006 - 2:50 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Erik sent me a link about how to correct the fans running constantly after removing AC.
The way one guy fixed it was jumping two pins on this plug below ![]() This was on a 5th gen. I was wondering if any of you 6th gen guys not running AC has the fans running full time. I just tryed jumping the plug but the fans still continued running. So, anyone else that could try to jump this plug and post the results that would be a great help. DEF -------------------- ![]() I will return one day. |
May 14, 2006 - 2:54 PM
i dont see how AC would make a difference or not.
there is a temp sensor on the passengers side of the radiator. you have to plug the 3s harness into it. if the sensor dosnt get pluged in, or is missing, the fans will stay on all the time, as a safetly feature. maybe the ST raditor dosnt have the sensor and thats why your fans are staying on? -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 14, 2006 - 3:15 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
If DG did your harness your fans will stay on all the time, he wires them that way on purpose, I believe that is what he told me. Mine stay on all the time too.
May 14, 2006 - 3:28 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
lagos is correct, the ST radiator does not have the sensor, therefore your fans will run all the time.
May 14, 2006 - 3:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
yap exactly how mine is...it starts running at normal op temp and never stops...lol tho i dont see this being a problem tho, atleast we wont overheat hahah
bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
May 14, 2006 - 4:02 PM
Well now. This means we should figure out how to get it working properly, I do not like that fans on all the time.
How would I wire this up to run properly ? DG I'm going to pm you. -------------------- ![]() I will return one day. |
May 14, 2006 - 4:07 PM
us ST guys are probably just going to have to swap to a GT radiator which has the sensor lagos is talking about (i think?). or even better...maybe a koyo one hMmMmM
May 14, 2006 - 4:12 PM
mine actually come on as soon as i turn the key to on, but i think that has something to do with my fan relay wire leading to nowhere..
im going to replace the radiator down the road with a GT one, simply because i dont like having to union the two lower radiator hoses together, but mark said even in his car with the koyo his fans were on all the time. but jeff if you figure it out with the ST radiator let me know! |
May 14, 2006 - 4:21 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
The fan temp wire comes from plug EA1 if i remember correctly. I will have to look it up for sure but i think it is a light green color wire. I think it might have a black stripe on it too?
dg -------------------- ![]() |
May 14, 2006 - 4:28 PM
QUOTE(lagos @ May 14, 2006 - 3:54 PM) [snapback]433891[/snapback] i dont see how AC would make a difference or not. there is a temp sensor on the passengers side of the radiator. you have to plug the 3s harness into it. if the sensor dosnt get pluged in, or is missing, the fans will stay on all the time, as a safetly feature. maybe the ST raditor dosnt have the sensor and thats why your fans are staying on? The absence of a looped circuit does make a difference. It is not just the temp sensor it is several sensors that if not working or disconnected the fans will run. When I removed my a/c, my fans stayed on, so a/c most definately makes a difference. -------------------- |
May 14, 2006 - 4:33 PM
i dont find it to be that big of a deal, but it is a constant reminder that we have done non oem work to our car and to me thats annoying
but like i said im a perfectionist, and i have a soft spot for oem quality things, which is why im going crazy trying to get my engine bay looking good. |
May 14, 2006 - 4:38 PM
Ok well I just jumped mine and it DID fix the fan problem. So basically it depends on which one of ur plugs/sensors isnt connected thats causing it.
So if you have fans constantly on after u remove your a/c - jump the grey plug that looks like above by the firewall. Jeff I'd leave it jumped because if your messing with something you wont know its fixed unless thats jumped. This post has been edited by Supersprynt: May 14, 2006 - 4:41 PM -------------------- |
May 14, 2006 - 5:03 PM
i just looked at my plug today. its a 2 wire plug with white and blue (with black stripe?) wires on it. it is located on the bottom of the radiator on the passengers side. if u dont have that pluged in, or dont have the sensor on your radiator, then the fans will stay on all the time.
i think in order to have eriks fix work, you also have to have a GT radiator with a temp sensor on there. This post has been edited by lagos: May 14, 2006 - 5:04 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 14, 2006 - 5:06 PM
sounds right to me lagos, unless of course like my wiring your fan relay leads no where
May 14, 2006 - 5:49 PM
Well I diagree with Art. There are several plugs in which the fan power runs through in order to create a closed loop. If any one of those plugs or sensors is malfunctioning/disconnected then the fans stay on. As it happens the plug in MY problem was the a/c. This doesnt mean its NOT that problem but could be a couple. If Jeff fixes his issue w/o jumping that plug then that would mean its a GT - only problem. As of right now I'm not so convinced the wiring is that different between trims.
May 14, 2006 - 5:53 PM
lets put it this way erik, my car is an ST and my engine harness is a GT harness mated with a 3sgte harness, the only two plugs on the harness not in use are cruise control and coolant temp.
May 14, 2006 - 5:54 PM
So what your saying is that your car doesnt know how hot your coolant is?
Thats a bad thing. -------------------- |
May 14, 2006 - 5:57 PM
the coolant temp sensor on the radiator is for deciding when to turn on the radiator fans, the coolant temp sensor on the thermostat is a diff sensor.
May 14, 2006 - 6:01 PM
QUOTE(Supersprynt @ May 14, 2006 - 6:54 PM) [snapback]433976[/snapback] So what your saying is that your car doesnt know how hot your coolant is? Thats a bad thing. there are 3 coolant temp sensors on the car. one for your gauge one for your ecu one for the radiator fans -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 14, 2006 - 8:39 PM
QUOTE(brianforster @ May 14, 2006 - 9:12 PM) [snapback]433927[/snapback] mine actually come on as soon as i turn the key to on, but i think that has something to do with my fan relay wire leading to nowhere.. im going to replace the radiator down the road with a GT one, simply because i dont like having to union the two lower radiator hoses together, but mark said even in his car with the koyo his fans were on all the time. but jeff if you figure it out with the ST radiator let me know! I didn't join 2 radiator hoses together for mine, i did at first but it poped off and I lost all my coolent and got stranded. After that I went to autozone and found a radiator hose from another car that fit perfect but I don't know what kind of car it was from. |
| Lo-Fi Version | Time is now: September 7th, 2026 - 10:59 PM |
