May 15, 2006 - 6:19 PM
Enthusiast ![]() ![]() Joined May 2, '06 From Nevada Currently Offline Reputation: 0 (0%) |
Hi,
My low fuel light comes on - I already checked twice - at ~ 4 gallons left (assuming previous owner did not change the tank Is it normal? The fuel gauge still shows almost one notch above empty. Val |
May 18, 2006 - 7:00 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
I believe that happens on most Toyotas. The light comes on early so you don't run out of gas. My dad runs his 5S Camry 40+ miles after the light comes on.
May 18, 2006 - 9:34 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) |
yeah mine does the same thing. When it gets a little below 1/4 it comes on. Not a big deal though.
May 18, 2006 - 11:36 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I like how it fades on and off a few times when getting low
then stays lit when it gets at a certain level. -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
May 18, 2006 - 1:04 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
mine too it fades...it depens on how you drive, but when youre at the quarter tank...you have about 70-100 miles to go till empty i reach 100 miles at a quarter tank
May 18, 2006 - 1:40 PM
QUOTE(valerit1 @ May 15, 2006 - 7:19 PM) [snapback]434357[/snapback] Hi, My low fuel light comes on - I already checked twice - at ~ 4 gallons left (assuming previous owner did not change the tank Is it normal? The fuel gauge still shows almost one notch above empty. Val here is a fix for that problem 1. go to the gas station 2. open your gas cap 3. pay a crazy amount of money for gas 4. fill up your tank. the problem should go away. sadly its only a temp fix and the problem will return in about a week or so. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 18, 2006 - 3:51 PM
I had exactly $40 when I went to the gas station. I didn't even fill up all the way... but it was close.
May 18, 2006 - 4:15 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
QUOTE(lagos @ May 18, 2006 - 1:40 PM) [snapback]435330[/snapback] QUOTE(valerit1 @ May 15, 2006 - 7:19 PM) [snapback]434357[/snapback] Hi, My low fuel light comes on - I already checked twice - at ~ 4 gallons left (assuming previous owner did not change the tank Is it normal? The fuel gauge still shows almost one notch above empty. Val here is a fix for that problem 1. go to the gas station 2. open your gas cap 3. pay a crazy amount of money for gas 4. fill up your tank. the problem should go away. sadly its only a temp fix and the problem will return in about a week or so. -------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
May 18, 2006 - 5:38 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) |
QUOTE(valerit1 @ May 15, 2006 - 6:19 PM) [snapback]434357[/snapback] Hi, My low fuel light comes on - I already checked twice - at ~ 4 gallons left (assuming previous owner did not change the tank Is it normal? The fuel gauge still shows almost one notch above empty. Val When you're driving, the gas will splash around in there, triggering the light on and off. When the light first comes on (and stays on), you are supposed to have 60 miles of driving before running out of gas. |
May 23, 2006 - 8:53 PM
[/quote] here is a fix for that problem 1. go to the gas station 2. open your gas cap 3. pay a crazy amount of money for gas 4. fill up your tank. the problem should go away. sadly its only a temp fix and the problem will return in about a week or so. [/quote] lagos.... you are the man...LMAO... -------------------- |
| Lo-Fi Version | Time is now: June 14th, 2026 - 1:53 AM |
