May 18, 2006 - 11:47 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
Disclaimer: I recently swap my own 3sgte motor with the acception of the wiring (DG Perf) so i have a pretty decent amount of knowledge when it comes to cars. now with that said.....
earlier i was in my drivers seat taking off the plastic pieces around the radio because i wanted to check the room for 3 guages. Therefore i took the plastic piece that holds the cig lighter off and to do that you need to disconect its wire from behind as well as another random plug next to it. I do a little measuring for about 15min. then put everything back. 1/2 hr later i get ready to leave and jump in the car again. I put it in first gear and try to take off.... the thing nearly died on me. I really had to gas it to keep it on and to get it moving about 4and half revs, and the thing bearly moved, like it was riding on 2 pistons or something. Naturally i pop the hood and look for any loose wires,sensors,vac hoses, etc, and everthing looked normal. tried it again and the same thing happed AGAIN... So i back track to what i did in the cabin, thinking maybe i knocked a ecu wire loose or something, and noticed i didnt plug the lighter back in or the random plug next to it. I put them back in and what do you know... the problem GOES AWAY! are you freakin kidding me? the lighter screws things up? or is that random plug an extremely critical piece that needs to be pluged in? someone please enlighten me as im always eager to learn. thank you for reading this long story and thanks ahead of time for any responses |
eggman40 Ok, WTF just Happened??? May 18, 2006 - 11:47 PM
Batman722 the lighter has 2 plugs behind it, one for power a... May 18, 2006 - 11:50 PM
Batman722 QUOTE(Batman722 @ May 19, 2006 - 12... May 19, 2006 - 12:12 AM
Chanh55 Egg... what is this random plug that you are talki... May 18, 2006 - 11:52 PM
eggman40 QUOTE(Chanh55 @ May 19, 2006 - 4:52 ... May 18, 2006 - 11:54 PM
defgeph Pic would be perfect. The cig lighter wouldnt effe... May 18, 2006 - 11:56 PM
lagos there are 2 plugs for the cig lighter....one for t... May 18, 2006 - 11:56 PM
eggman40 hope this helps May 19, 2006 - 12:03 AM
Chanh55 Egg... like what everyone else is saying... the la... May 19, 2006 - 12:11 AM
lagos those have nothing to do with how your car runs. May 19, 2006 - 12:13 AM
eggman40 Man i know guys thats what i thought, even in my h... May 19, 2006 - 12:20 AM
lagos put it on vid, but check your cel codes 1st May 19, 2006 - 12:24 AM
eggman40 QUOTE(lagos @ May 19, 2006 - 5:24 AM... May 19, 2006 - 12:33 AM
ZacMan1987 Could one of the plugs have landed on his ECU some... May 19, 2006 - 1:55 AM
lagos QUOTE(eggman40 @ May 19, 2006 - 1:33... May 19, 2006 - 2:00 AM
WannabeGT4 Sounds like you just put it in third gear by mista... May 19, 2006 - 10:04 AM
bojangles_8686 QUOTE(WannabeGT4 @ May 19, 2006 - 11... May 19, 2006 - 10:12 AM
toyotacrazy Hey guys,
Have you disconnected the wires agai... May 19, 2006 - 7:51 PM
K-ESD QUOTE(toyotacrazy @ May 19, 2006 - 9... May 21, 2006 - 9:52 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 28th, 2026 - 5:32 PM |
