> air bag light on, what happened?
post May 19, 2006 - 11:15 AM
blackbullet
Joined Jul 21, '04
From Fresno, CA
I fixed my ac pipes took it out weld the hole, put it back on. when i did that i unplug the relay near the compressor for the abs and after i put everything back in place and start up the enging to recharge my ac system i notice that my air bag light was on. what could it be? a fuse? or what? any advice would be helpful thanks guys...
post May 21, 2006 - 7:46 AM
bindertch
Joined Aug 18, '04
From Silverdale, WA
Get the system scanned they will be able to read the code and tell you what is wrong. Might be an easy fix.
EDIT: Also I just found out. If your horn and cruise control doesn't work then it might be the clockspring in the steering column. Mine went out in my truck (Toyota T100) and it isn't cheap. If the other things do work then it is something else. Good luck.
This post has been edited by bindertch: May 23, 2006 - 1:56 PM
Lo-Fi Version Time is now: May 25th, 2026 - 11:11 PM
