May 20, 2006 - 10:29 AM
Enthusiast ![]() ![]() Joined Aug 14, '04 From Toledo, Ohio Currently Offline Reputation: 0 (0%) |
So I finally got my exhaust done. It's such a HUGE difference...I had no idea. my old exhaust had so many leaks, was crush bent, and was only 2 inches...if that. now it sounds so much better, not too loud and has a great low growl to it. Im boosting ~13psi now. kinda scary at times.
now my mods list includes: (92 JDM Mr2) MBC (@13psi) Walbro 255lph ACT Stage 2 clutch w/ fidanza flywheel Full 3" exhaust!!! Also, Im pretty sure I hit fuel cut a few times, but i have the vac hose plugged going from the turbo to the t-vsv so I shouldnt have fuel cut should I? maybe im misunderstanding something about how it works. i have an hks FCD but its not installed because since my harness had been re-wired twice, i cant tell which wire i need to splice...is there a link to the pinouts for the 92 jdm mr2 ecu somewhere? comments? suggestions for my next mod? i'll have a chance to get it dyno tuned at a place in Columbus in the next few weeks. any idea how much power i should have at the wheels with these mods? |
May 20, 2006 - 10:54 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
That doesn't effect fuel cut. Your fuel cut is still at 12psi you have to raise your fuel cut to change it.
May 20, 2006 - 11:00 AM
take the vac line that goes to the map sensor (turbo presure sensor), disconnect and cap oof the 2 ends. you will have no fuel cut. just keep an eye on your boost gauge.
3in exhaust is a must for any turbo car. i love mine. what muffler did you go with for your exhaust? This post has been edited by lagos: May 20, 2006 - 11:01 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 20, 2006 - 11:30 AM
i stuck with the same Ractive muffler that i already had because it always had the best sound out of most others that ive heard.
i'll probably just turn the boost back down a little till i can get it tuned. there arent many dyno's around here so i'll make due with 11 or 12 psi...plenty. |
May 20, 2006 - 12:34 PM
Enthusiast ![]() ![]() ![]() Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) |
do you have a downpipe comming fromt he turbo or is that first cat still there?
-------------------- BANNED!
May 20, 2006 - 12:37 PM
QUOTE(burneeed @ May 20, 2006 - 5:34 PM) [snapback]436026[/snapback] do you have a downpipe comming fromt he turbo or is that first cat still there? oh, yeah that first cat is still there...so i guess its not a FULL 3". What downpipes are you guys using? |
May 20, 2006 - 12:38 PM
if you have your old muffler.....isint the muffler smaller then 3in causing a bottole neck?
get a full 3in magnaflow. i love mine and since i got it done, everyone always says how great the car sounds! -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 20, 2006 - 12:49 PM
Magnaflow or Top speed FTW!
May 20, 2006 - 1:54 PM
QUOTE(lagos @ May 20, 2006 - 5:38 PM) [snapback]436029[/snapback] if you have your old muffler.....isint the muffler smaller then 3in causing a bottole neck? get a full 3in magnaflow. i love mine and since i got it done, everyone always says how great the car sounds! yeah its probably a minor bottleneck..the inlet isnt quite 3" but its still bigger than the rest of my old exhaust. i'll look into the magnaflow. |
May 21, 2006 - 12:11 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
QUOTE(gtfc115 @ May 20, 2006 - 11:30 AM) [snapback]436008[/snapback] i stuck with the same Ractive muffler that i already had because it always had the best sound out of most others that ive heard. i'll probably just turn the boost back down a little till i can get it tuned. there arent many dyno's around here so i'll make due with 11 or 12 psi...plenty. hey man i did not know there was another turbo celica in the north west ohio area -------------------- ![]() |
May 21, 2006 - 10:03 AM
QUOTE(trd94 @ May 21, 2006 - 5:11 AM) [snapback]436169[/snapback] hey man i did not know there was another turbo celica in the north west ohio area yeah there are a couple 3s swaps here in toledo...mine and another in a 5th gen. let me know how you do on the dyno. i was gona turbo my 7a before i did the swap, but never went through with it. i'd like to see what kinda numbers i coulda have put down. |
May 21, 2006 - 1:20 PM
QUOTE(gtfc115 @ May 21, 2006 - 10:03 AM) [snapback]436234[/snapback] QUOTE(trd94 @ May 21, 2006 - 5:11 AM) [snapback]436169[/snapback] hey man i did not know there was another turbo celica in the north west ohio area yeah there are a couple 3s swaps here in toledo...mine and another in a 5th gen. let me know how you do on the dyno. i was gona turbo my 7a before i did the swap, but never went through with it. i'd like to see what kinda numbers i coulda have put down. i will let you know, -------------------- ![]() |
May 21, 2006 - 2:19 PM
QUOTE(trd94 @ May 21, 2006 - 6:20 PM) [snapback]436300[/snapback] QUOTE(gtfc115 @ May 21, 2006 - 10:03 AM) [snapback]436234[/snapback] QUOTE(trd94 @ May 21, 2006 - 5:11 AM) [snapback]436169[/snapback] hey man i did not know there was another turbo celica in the north west ohio area yeah there are a couple 3s swaps here in toledo...mine and another in a 5th gen. let me know how you do on the dyno. i was gona turbo my 7a before i did the swap, but never went through with it. i'd like to see what kinda numbers i coulda have put down. i will let you know, most of it was done by a small non-tuner auto repair shop...the had no experience with it, but stuck with it and did a good job IMO. some of the work was also done at a place called Gearheadz...overpriced to say the least. anyways, if/when you're ready to do the swap, they're in Perrysburg called Express Auto. Great guys, and now they have experience with the swap after troubleshooting mine for 2 years |
May 22, 2006 - 7:45 AM
QUOTE(gtfc115 @ May 21, 2006 - 2:19 PM) [snapback]436328[/snapback] QUOTE(trd94 @ May 21, 2006 - 6:20 PM) [snapback]436300[/snapback] QUOTE(gtfc115 @ May 21, 2006 - 10:03 AM) [snapback]436234[/snapback] QUOTE(trd94 @ May 21, 2006 - 5:11 AM) [snapback]436169[/snapback] hey man i did not know there was another turbo celica in the north west ohio area yeah there are a couple 3s swaps here in toledo...mine and another in a 5th gen. let me know how you do on the dyno. i was gona turbo my 7a before i did the swap, but never went through with it. i'd like to see what kinda numbers i coulda have put down. i will let you know, most of it was done by a small non-tuner auto repair shop...the had no experience with it, but stuck with it and did a good job IMO. some of the work was also done at a place called Gearheadz...overpriced to say the least. anyways, if/when you're ready to do the swap, they're in Perrysburg called Express Auto. Great guys, and now they have experience with the swap after troubleshooting mine for 2 years awesome !! thanks for the info -------------------- ![]() |
May 22, 2006 - 8:41 AM
Enthusiast ![]() Joined Mar 24, '06 From Slough,Berkshire,UK Currently Offline Reputation: 0 (0%) |
I take it that none of you guys that have done the 3s-GTE swap suffer from boost creep with the 3" exhausts? in the UK if we use the standard ct20 on a 3" system we normally get boost creep, it might be down to us having 99 ron fuel. It happened to me the other day and went up to 21.4 PSI then I hit fuel cut and spat a big flame out of the back
Nathan -------------------- 1994 JDM ST205 WRC with 17" OZ Chrono's wearing 215/45/17 Eagle F1's. HKS Induction Kit, Blitz DV, Decat and full SS System, Blitz SBC-iD and Power Meter running at 1.12Bar = 17mpg and a lot of fun
| Lo-Fi Version | Time is now: July 28th, 2026 - 6:35 PM |
