May 20, 2006 - 1:53 PM
Enthusiast ![]() ![]() Joined Apr 4, '06 From Minnesota Currently Offline Reputation: -1 (0%) |
Okay I took my engine to the shop and they said it is a "knock". so they said i needed a valve adjustment. i said my engine is hydrolic and can't do adjustment but they looked it up and said they could do it cause its the same as a camry motor. but they also said i need new lifters if the valve adjustment wasn't the case? but im not into the engine stuff so i dont know. i just have to agree with the mechanics. the total to adjust my valves were 163 dollars and/or 455 dollars to get new lifters. anyone know? well cha cha i gotta go to other mechanics.
May 20, 2006 - 2:59 PM
take it to another "mechanic"
if anything, you need a "valve SHIM adjustment" -------------------- Former Team 5SFTE pro member ;)
May 20, 2006 - 8:38 PM
QUOTE(presure2 @ May 20, 2006 - 2:59 PM) [snapback]436058[/snapback] take it to another "mechanic" if anything, you need a "valve SHIM adjustment" what's that presure2? is that hard to do on your own? i think that's what it is they're doing. lmk the info on the valve shims. thanks presure2 -------------------- ![]() |
| Lo-Fi Version | Time is now: September 15th, 2026 - 10:16 AM |
