> What's your 5sfte 3sgte 2 bar Map Voltages?
post May 20, 2006 - 5:51 PM
penguininatux
Joined Dec 21, '05
From Seattle, Washington
Hey. i installed an msd 2 bar map sensor, and the safc doesnt seem to be working with it very well. With the new 2 bar installed and i go to "SENSOR CHECK", NOT "SENSOR TYPE" i can see the in-1 voltage. It is 2.250 with the car just "ON" NOT STARTED. The stock map sensor was 4.500.
Anyways my quesiton is for people with a 5sfe turbo and a 3sgte map sensor.. What In-1 Voltage are u getting when the car is just "ON" Not STARTED.
ie: go to ETC, and then go to "Sensor Check" to find these voltages on your apexi SAFC II.
AGAIN THESE ARE NOT THE "SENSOR TYPE" IN AND OUT SETTINGS.
I would just like to know the difference in voltage between my MSD 2 bar, and the 3sgte 2 bar, because im considering buying one.
Thanks
Dan.
This post has been edited by penguininatux: May 20, 2006 - 5:53 PM
<a href="http://tinypic.com"><img src="http://i4.tinypic.com/103wx8n.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
post May 20, 2006 - 7:12 PM
.050
sorry i didnt answer your PM right away, since its the wifes car, sometimes its not just as easy as walking outside and checking somthing if shes not home.
post May 20, 2006 - 7:34 PM
penguininatux
Joined Dec 21, '05
its all good.. i really appreciate the help though. and i didnt know u did the car for your wife!!.. that's so tite. its like some chicks like expensive jewlery and some like shoes. but your wife gets a turbo celica. =].. your wife has good taste =]. Anyways thanks man
later
Oh yeah.. and its really weird. when ever i get a negative correction % my idle sounds really sparatic. like goes from 1800rpm to 1400rpm and then back up in a matter of a second or so. and repeats over and over. And it seems to idle really high (ie :1800-2000)
well ima go mess with it some more
ttyl
Dan.
Lo-Fi Version Time is now: August 25th, 2026 - 8:40 AM
