May 22, 2006 - 12:27 AM
![]() Enthusiast ![]() ![]() Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
I was wondering which spring would be the best type of spring.
All I know is the following: Progressive= spring rate is variable as the spring is compressed aka the spring rate is usually softer in the beginning but as it is compressed more and more the spring rate goes up. The advantage of progressive springs are that they give a softer "stock-like" ride, but are more expensive to manufacture and not as predictable when being loaded up going through corners? Straight= The same spring rate as the spring is compressed. The advantage of these springs are they are cheaper and since they compress at the same rate they would be more predictable? but the spring rates can either be too stiff or soft. I'm confused about which is the better "all purpose" spring. Any thoughts or imput would be greatly appreciated |
hellsyphon Progressive vs. Straight Rate Springs? May 22, 2006 - 12:27 AM
presure2 IMO a progressive rate spring is better for your a... May 22, 2006 - 7:41 AM![]() ![]() |
| Lo-Fi Version | Time is now: May 16th, 2026 - 6:33 PM |
