> Boosting, Car Not Boosting To Full 10psi
post May 22, 2006 - 9:42 AM
GMoney
Joined Jan 18, '06
From St.lucia
hey guys my car refusing to boost to 10 psi then i get a feul cut frown.gif wat could be the prob ...someone told me it could bbe my soloid that is goin bad
post May 22, 2006 - 11:11 AM
You probably have a boost leak. Check all your connections for loose fittings or cracked hoses.
post May 22, 2006 - 7:31 PM
trd94
Joined Jan 9, '05
From green springs ohio
what size is your exhaust pipe size and your down pipe , before i got my 2 1/2 exhaust pipe done i was using the factory pipe and i could not boost any more than 5 psi , now i have 3 in down pipe and a 2 1/2 exhaust pipe all the way back ,i also got rid of all the cats and pre mufflers , i run two high flow cats at 3" in and out also i ran the exhaust under the axle not over it the less bend the more flow ,better boost . i am boosting at 7psi every day and when i want to really run her hard i take it to 10psi for know wink.gif i hope this helps you out with your 3sgte i know it helped me with my 7afte
This post has been edited by trd94: May 22, 2006 - 7:35 PM
post May 22, 2006 - 10:32 PM
GMoney
Joined Jan 18, '06
From St.lucia
kool thanx man but i have a 3" exhaust all the way back ... but i think it has something to with a tapping noise i am hearing the number 4 cylinder area
post May 22, 2006 - 10:42 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
i doubt that the exhaust size is the problem. you probably either have a boostleak or there is something wrong with your wastegate.
post May 22, 2006 - 11:25 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Check engine light on ?
I will return one day.
post May 23, 2006 - 8:21 PM
burneeed
Joined Dec 18, '05
From BANNED
if its not boosting to 10psi then I would put money on tvsv... did you recently do the swap or try to add a boost controller?
BANNED!
post May 23, 2006 - 8:50 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
I say boost leak FTW. If not, then like he said...TVSV!
Lo-Fi Version Time is now: July 29th, 2026 - 5:50 AM
