> hesitation problems
post May 23, 2006 - 11:10 AM
96c-oneconv
Joined May 12, '04
From canada
As some of you might already know I have a 3rd gen 3sgte st205 swap. My problem started yesterday. But it's not consistant. Basically sometimes it wont boost at all and bogs out when stepping on the gas in every gear. Then it goes back to boosting 15psi which is my current set-up. My current mods are turbosmart blowoff, high flow intake, greddy sp exhaust. The rest is still stock. Any ideas?
Thanks
- 96c-oneconv   hesitation problems   May 23, 2006 - 11:10 AM
- - gtfc115   QUOTE(96c-oneconv @ May 23, 2006 - ...   May 23, 2006 - 6:57 PM
- - 96c-oneconv   No the weather as been in the 50's lately and ...   May 23, 2006 - 8:15 PM
- - 96c-oneconv   Can anybody help out?   May 25, 2006 - 3:38 PM
- - lagos   check your ecu for codes check for boost leaks   May 25, 2006 - 4:04 PM
- - 96c-oneconv   I'm not getting any check engine light and the...   May 26, 2006 - 11:15 AM
- - Rjb23   I would bet your bov is leaking.   May 26, 2006 - 3:03 PM
- - defgeph   Can I suggest bad batch of gas.   May 26, 2006 - 3:25 PM
- - presure2   how old are your ignition components?   May 26, 2006 - 3:26 PM
|- - 96c-oneconv   Well I narrowed it down to the electrical system. ...   May 27, 2006 - 7:57 PM
|- - presure2   QUOTE(presure2 @ May 26, 2006 - 4:26...   May 28, 2006 - 8:31 AM
- - Kadett   3rd gen 3s-gte alternator are prown to brake when ...   May 28, 2006 - 9:02 AM
- - 96c-oneconv   Thanks I going to change all the ignition componen...   May 28, 2006 - 2:16 PM
|- - jgreening   QUOTE(96c-oneconv @ May 28, 2006 - ...   May 28, 2006 - 9:34 PM
- - lagos   QUOTE(Kadett @ May 28, 2006 - 10:02 ...   May 28, 2006 - 10:38 PM
- - 96c-oneconv   The plugs were changed 150 miles ago. As for plug ...   May 29, 2006 - 8:51 AM
- - Supersprynt   Sounds like a loose connection with an ignition or...   May 29, 2006 - 11:35 AM
- - celicasteve   ahh. check the grounding on the pump! if it st...   May 29, 2006 - 11:39 AM
- - lagos   QUOTEAs for plug wires, rotor, cap are still what ...   May 29, 2006 - 11:44 AM
Lo-Fi Version Time is now: September 8th, 2026 - 4:04 AM
