May 27, 2006 - 2:00 PM
I got a new code after i got the header on, P0420, catalyst effieciency below threshold...so either the O2 sensors are bad or not tight enough?
This post has been edited by LewFX: May 27, 2006 - 2:53 PM -------------------- ![]() |
LewFX Check Engine Light Came On Again May 27, 2006 - 2:00 PM
Batman722 try reseting the ECU and seeing if it comes back a... May 27, 2006 - 11:54 PM
LewFX first i tried resetting the ecu and it came back a... May 28, 2006 - 12:14 AM
presure2 make sure the plug is securly connected May 29, 2006 - 6:40 AM
toyotacrazy Do you have a catalytic convertor? If so its prob... May 29, 2006 - 6:53 AM
presure2 QUOTE(toyotacrazy @ May 29, 2006 - 7... May 29, 2006 - 6:55 AM
LewFX still no problems with it yet, as soon as the ligh... May 29, 2006 - 12:44 PM
bindertch If it does come back on you should think about mov... May 29, 2006 - 9:40 PM
LewFX well today the CEL came on again, what to do now..... Jun 1, 2006 - 7:56 PM
Bitter some 3rd gen eclipse folk have had luck using a sp... Jun 1, 2006 - 8:14 PM
LewFX the guy who sells the header told me that it was s... Jun 1, 2006 - 9:49 PM
Bitter ok, does your car have a black plastic thing near ... Jun 1, 2006 - 9:58 PM
LewFX diagnostic Jun 1, 2006 - 10:40 PM
Bitter QUOTE(LewFX @ Jun 1, 2006 - 10:40 PM... Jun 3, 2006 - 2:56 AM
LewFX bump Jun 2, 2006 - 9:10 PM
LewFX possible probs are:
1) three-way catalytic coverte... Jun 3, 2006 - 11:20 PM
bindertch The problem is that the second O2 sensor is supose... Jun 5, 2006 - 6:40 PM
LewFX ya i kept everything when i get it smogged. so the... Jun 5, 2006 - 8:05 PM
LewFX well bought a new O2 sensor and reset the ecu, hop... Jun 5, 2006 - 10:01 PM
toyotatech QUOTE(LewFX @ Jun 5, 2006 - 10:01 PM... Jun 6, 2006 - 9:03 AM
bindertch QUOTE(LewFX @ Jun 6, 2006 - 1:05 AM)... Jun 6, 2006 - 2:10 PM
Bitter try getting a universal cat thats meant for a larg... Jun 6, 2006 - 2:59 PM
LewFX well since i know the guy who does the smog, ill t... Jun 6, 2006 - 7:59 PM
LewFX well what do you know, it came on again, what a su... Jun 9, 2006 - 8:18 PM
LewFX should i cut the bottom sensor and jimmy it to the... Jun 11, 2006 - 8:08 AM
Bitter no, dont do that. extend the sensor and have it... Jun 11, 2006 - 6:17 PM
Bitter http://www.club3g.com/forum/showthread.php?t=55284... Jun 11, 2006 - 8:08 PM
LewFX ill try that. Jun 11, 2006 - 8:19 PM
LewFX k bought some anti-seize, the 2 foulers, drilled i... Jun 11, 2006 - 10:01 PM
LewFX okay i got the fix done today, lets hope this fixe... Jun 12, 2006 - 6:30 PM
Bitter cool, keep us updated as to wether or not it works Jun 12, 2006 - 6:46 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 30th, 2026 - 7:04 PM |
