> radiator fluid boiling, car overheating
post May 28, 2006 - 8:43 PM
trdcelica94
Joined Apr 29, '03
From socal
has anyone had there car over heat due to radiator fluid boiling an getting hot my brother is having this problem seeing what might cause this someone told me i might of blow a head gasket
This post has been edited by trdcelica94: May 28, 2006 - 9:01 PM
post May 28, 2006 - 8:45 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
check your thermostat/replace it. make sure your fan is working also while idling. I seriously doubt its a head gasket- you would know from other reasons if your head gasket was out.
post May 28, 2006 - 9:02 PM
trdcelica94
Joined Apr 29, '03
From socal
so most likely its the radiator fans or the thermostat thats broken i dont think i saw the fans spin does that mean the radiator is bad
post May 29, 2006 - 12:19 AM
Whens the last time you actually flushed the system? Coolant does go bad after awhile, you may need some new coolant.
post May 29, 2006 - 1:34 AM
trdcelica94
Joined Apr 29, '03
From socal
forreal would that casue it to mal function?.....do i add water to the radiator or the other whole that says coolant or do i put antifreeze im confused about that too do u add water when the anti freeze says do not add water?
post May 29, 2006 - 3:39 AM
Jen
Joined Jul 14, '03
From Jacksonville, FL
Ouch that sounds like what happened when my radiator cracked.. had to replace both the radiator and the fan.
It says don't add water because it was already mixed with water.. it's like 50/50 if I remember correctly. Someone correct me if I'm wrong.
YoungSurvival.Org
post May 29, 2006 - 4:05 AM
CheesyLobster
Joined Jul 19, '04
QUOTE(Jen @ May 29, 2006 - 1:39 AM) [snapback]438884[/snapback]
just buy coolant, its premixed antifreeze and water. you can take your car in and have it flushed or do it yourself. check out this link: http://www.carcentral.net/content/guides/H...olingSystem.php its kind of difficult so you may just want to get it professionally done/ have them replace the termostat too.
post Jun 1, 2006 - 1:42 PM
celicak
Joined May 20, '06
From williamsburg, va
K.I.S.S. first off you want to work from the easiest fixes back. so i would go ahead and get a new radiator cap and thermostat. the reason for the cap would be that when a liquid is under pressure it's boiling point increases therefore if the radiator cap has a bad seal or whatever then the boiling point would go down causing the fluid to boil. get the thermostat just to be safe they aren't expensive and they're relatively easy to change out. then if that doesn't work have the system flushed and replaced. um...yeah that's about it.
post Jun 1, 2006 - 2:23 PM
bigal004321
Joined Jun 21, '05
From New york
also check the waterpump...wiggle the part where the belt sits and spins the pump..if it is loose then you need a new waterpump...they are really cheap so dont think it is a big fix...like 20-25 to buy one.
Bigal
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
Lo-Fi Version Time is now: May 17th, 2026 - 11:37 PM
