May 31, 2006 - 5:53 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Can anyone tell me how to get the ring that holds the bov to the flange in? It is driving me nuts!
May 31, 2006 - 6:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
needlenose pliers, its just a big c clip, two people makes it real easy.
have the second person put a flathead screwdriver on the end of the c clamp and press down, this will hold the clamp at an angle, with the back end down in the flange and the two ends of the c clamp angled up, well get the needle nose pliers in the small holes of the c clamp, press it and push down on your end while the other person holds the other end into the flange, its a pain in the ass but in the end its a pretty good way to hold the seal. |
May 31, 2006 - 7:44 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
-------------------- ![]() Project ST204.5 99.88946% complete... |
May 31, 2006 - 7:47 PM
snap ring pliers.
May 31, 2006 - 7:48 PM
Thanks for the caption.
May 31, 2006 - 8:08 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
snap ring pliers with the 90 degree bend on the point is the easier way
bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
May 31, 2006 - 8:21 PM
Enthusiast ![]() ![]() Joined Jun 21, '05 From New york Currently Offline Reputation: 1 (100%) |
how much are those pliers?
bigal -------------------- 1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
May 31, 2006 - 8:39 PM
bought mine for like 14 bucks at pep boys and it came with different tips, there were a few 90 degree bent tips also
May 31, 2006 - 8:42 PM
psh needle nose pliers skinny enough will work, if your poor like me
May 31, 2006 - 9:13 PM
QUOTE(BBoYRuGGeD @ May 31, 2006 - 9:39 PM) [snapback]439946[/snapback] bought mine for like 14 bucks at pep boys and it came with different tips, there were a few 90 degree bent tips also bboy same here! ... tip... get the most heavy duty one they have. that snap ring is a pain in the ass. you can also take the cover off the bov to avoid scratching it and it will make installing the snap ring less of a pain. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 1, 2006 - 8:18 AM
Yea I'm gonna get the snap ring pliers, I already took the cover off to make it easier.
Jun 1, 2006 - 8:20 AM
QUOTE tip... get the most heavy duty one they have. X2 -------------------- Former Team 5SFTE pro member ;)
Jun 2, 2006 - 10:58 PM
just bring it up here Rob and we will tackle it
Jun 3, 2006 - 10:34 PM
Well snap ring pliers were useless, ended up putting it on useing vise grips, channel locks and 2 screw drivers. By starting it one side then using the channel locks to compress it and used the screwdrivers to pry the ring in.
| Lo-Fi Version | Time is now: August 21st, 2026 - 12:56 PM |
