Jun 2, 2006 - 10:14 AM
![]() Enthusiast ![]() ![]() Joined Jun 14, '04 From Buffalo, NY Currently Offline Reputation: 6 (100%) |
hey guys,
recently i have been hearing this odd "tat-tat-tat" noise coming from the front driver's side of my car whenever i make turns that are moderatly sharp thanks for your help |
Jun 2, 2006 - 10:33 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
you driver's side CV shaft is dying
-------------------- ![]() -Rémy 02 SiR, 08 250R |
Jun 2, 2006 - 11:00 AM
is that an easy fix? or would it be expensive to have a shop do it?
thanks for the help btw! |
Jun 2, 2006 - 12:14 PM
I've experienced this when I first lowered my car. If you look at the top plate of the strut, there should be a little groove that should lock. I am not technical with the correct term but I noticed tat sounds when I turned sharp. I had to redo the installation after knowing it locked, everything seems fine. I mean your description matches my experience but I cannot relate so much if you haven't lowered your car, unless the same part I am talking about has worn out or has gotten loose. Sorry I could not provide accurate detail.
Jun 2, 2006 - 12:17 PM
QUOTE(trdproven @ Jun 2, 2006 - 1:14 PM) [snapback]440392[/snapback] I've experienced this when I first lowered my car. If you look at the top plate of the strut, there should be a little groove that should lock. I am not technical with the correct term but I noticed tat sounds when I turned sharp. I had to redo the installation after knowing it locked, everything seems fine. I mean your description matches my experience but I cannot relate so much if you haven't lowered your car, unless the same part I am talking about has worn out or has gotten loose. Sorry I could not provide accurate detail. This what ur talking about:
Jun 2, 2006 - 1:25 PM
cool...thanks for the help guys...
| Lo-Fi Version | Time is now: August 25th, 2026 - 5:42 AM |
