> misfire? boost leak? vacuum leak? arrgghh NOW WITH VIDS!
post Jun 2, 2006 - 3:09 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok so today was the first road trip to be taken in my car, but i made it like 20 miles and it started feeling like it was misfiring.
the other day i spoke to art about this problem, he said it was probably the same boost leak that causes my car to stall out when i shift to nuetral after my blow off valve goes off.
well i found this hose that was loose and replaced it and the problem went away (i said it felt like the car was missing, but i wasnt sure and he said boost leak) then i took off the hose and the car acted the same, little stumbly, and at idle it does a little "pop pop pop pop pop pop" thing.
today that problem came back 20 miles into my trip, but worse, i could definitly diagnose this as a misfire, the car was very hesistant when the gas was pressed and even trying to maintain 65mph i got some misfire-esque symptoms.
im gonna look in the bgb on how to test the continuity of my plug wires because i really dont wanna replace them if its not necessary, money is really tight ATM.
i just replaced the plugs with ngkr7e's gapped at .028 or .28 im not sure which, i used one of those round spark plug gapper thigns to do this.
yesterday i ran the boost leak tester idea that art had and found one, my throttle body was leaking, but that didnt fix any problems, i could not find any more but it had been a long day and since i couldnt hear loud hissing anymore i gave up, im gonna do it again soon with the soapy water bit.
does anyone have any ideas as to what my problem is? can a vacuum leak cause me to misfire?
could bad plug wires cause me to misfire only sometimes, not 100% of the time?
This post has been edited by brianforster: Jun 6, 2006 - 7:37 PM
- brianforster   misfire? boost leak? vacuum leak? arrgghh NOW WITH VIDS!   Jun 2, 2006 - 3:09 PM
- - Supersprynt   Misfiring can be a host of different problems. You...   Jun 2, 2006 - 3:16 PM
- - BBoYRuGGeD   yah bad sparkplug wires will cause hesitation. if ...   Jun 2, 2006 - 3:16 PM
- - brianforster   i was gonna order them from toyota today but he sa...   Jun 2, 2006 - 3:23 PM
- - burneeed   I would replace the entire ignition. When I first...   Jun 2, 2006 - 3:30 PM
- - BBoYRuGGeD   if you have 7 bolts on your exhaust manifold your ...   Jun 2, 2006 - 3:34 PM
- - brianforster   i really dont have money to replace the entire ign...   Jun 2, 2006 - 3:39 PM
- - brianforster   well mark just told me that the plug wires, dist c...   Jun 2, 2006 - 4:51 PM
- - lagos   you can test the cap and wires with a multimeter. ...   Jun 2, 2006 - 5:00 PM
- - presure2   ahh the joys of swapping.. the 3sgte is very sensi...   Jun 2, 2006 - 5:08 PM
|- - jgreening   QUOTE(presure2 @ Jun 2, 2006 - 5:08 ...   Jun 2, 2006 - 6:34 PM
- - brianforster   the problems have just started though, i just chec...   Jun 2, 2006 - 5:22 PM
- - toyotacrazy   You should check the wires by pulling the tubes ou...   Jun 2, 2006 - 5:33 PM
- - brianforster   i got rid of my code 21 but it still does it its ...   Jun 2, 2006 - 5:51 PM
- - brianforster   i made a boost leak tester already, i just ran out...   Jun 2, 2006 - 7:18 PM
- - brianforster   guys im pretty sure i am running ultra rich and ho...   Jun 2, 2006 - 7:41 PM
- - Rjb23   A boost leak will cause you to run rich, because y...   Jun 2, 2006 - 9:03 PM
- - brianforster   well im not getting any more obvious boost leaks s...   Jun 4, 2006 - 3:36 PM
- - Kadett   This is the same problem a fellow dutch celica own...   Jun 4, 2006 - 3:42 PM
- - lagos   QUOTEnow whenever i get over 3k rpms teh car start...   Jun 4, 2006 - 5:53 PM
- - brianforster   well we cleaned off and regapped my spark plugs, a...   Jun 4, 2006 - 6:24 PM
- - brianforster   scratch that the car started ****ign up royally to...   Jun 5, 2006 - 3:18 PM
- - BBoYRuGGeD   dont forget cap and rotor bboy   Jun 5, 2006 - 3:27 PM
- - brianforster   i changed the rotor since it was 6 bucks but the c...   Jun 5, 2006 - 3:34 PM
|- - BBoYRuGGeD   QUOTE(brianforster @ Jun 5, 2006 - 8...   Jun 6, 2006 - 5:49 AM
- - jgreening   I agree with Bboy. Even when the engine is profes...   Jun 6, 2006 - 1:01 PM
- - brianforster   well i replaced the wires today and it still does ...   Jun 6, 2006 - 1:11 PM
- - brianforster   some vids: Engine bay, idle Engine Bay 2, with r...   Jun 6, 2006 - 7:02 PM
- - Silver94CelicaOwner   What sort of spark plugs are you using with your s...   Jun 7, 2006 - 11:56 AM
- - brianforster   i switched to those plugs last week, the only othe...   Jun 7, 2006 - 12:50 PM
- - playr158   if you didn't get 90% of the gas outta your ta...   Jun 7, 2006 - 1:33 PM
- - CheesyLobster   sounds to me like you are running rich. get your i...   Jun 7, 2006 - 3:53 PM
- - brianforster   right now i am running open downpipe also manny...   Jun 7, 2006 - 3:59 PM
- - playr158   FIX THE STUPID LEAK   Jun 7, 2006 - 4:00 PM
- - lagos   QUOTE(brianforster @ Jun 7, 2006 - 4...   Jun 7, 2006 - 4:01 PM
- - CheesyLobster   get your exhaust done. i don't think the after...   Jun 7, 2006 - 4:04 PM
- - brianforster   QUOTE(lagos @ Jun 7, 2006 - 9:01 PM)...   Jun 7, 2006 - 4:22 PM
- - presure2   i would definetly get the aftermarket manifold off...   Jun 7, 2006 - 4:40 PM
- - brianforster   no i havent, because it seems impossible to reach ...   Jun 7, 2006 - 9:05 PM
- - brianforster   hey guys, this is a public service announcement DO...   Jun 8, 2006 - 2:12 PM
- - playr158   QUOTEit is the most paint in the ass thing ever b...   Jun 8, 2006 - 2:39 PM
- - brianforster   give me some credit dan, i know i have to unbolt t...   Jun 8, 2006 - 2:47 PM
- - CheesyLobster   SSautochrome is notorious for being a bad company....   Jun 12, 2006 - 7:02 AM
- - teal_terrorGT   QUOTE(CheesyLobster @ Jun 12, 2006 - 7...   Jun 26, 2006 - 12:25 AM
Lo-Fi Version Time is now: August 31st, 2026 - 12:37 AM
