> power windows and door locks, installing
post Jun 6, 2006 - 2:35 AM
d-roCk
Joined May 25, '05
From Reno
Hey guys well sorry if this is a repost i tried searching but i couldn't find anything. well i juss went to the junk yard and saw a celica with power windows and power door locks i was wondering how hard is it to install everything in my car to make it powered because it is soo inconvient to have to reach across the car and try to roll down the window and unlock the car for the passenger. I was also wondering would it be more simple to just get the whole doors or just get everything i need for the powered windows and door locks. Al i know is that i need the motor, regulator, solenoid, latches, and of course door panels and is their anything else? thanks in advance for any advice and help! biggrin.gif
This post has been edited by d-roCk: Jun 6, 2006 - 2:37 AM
post Jun 6, 2006 - 2:37 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
to install stock door locks and windows you need the body harness from a donor car, this requires removal of the dash.. i did it but only because i had to take the dash off to replace the airbags, i would not reccommend it to anyone else..
cheaper and easier would be to buy the kits on ebay and wire it up yourself
post Jun 6, 2006 - 5:44 AM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
the easiest route would be to swap doors but that would cost a lil more i think.... especialy after paint
the other option is the conversion
you will also need the door lock control module located near the ignition switch
and print this
http://www.celicatech.com/vfewdsou/1995/95...ic/doorlock.pdf
http://www.celicatech.com/vfewdsou/1995/95...ic/powrwind.pdf
This post has been edited by K-ESD: Jun 6, 2006 - 5:28 PM
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jun 6, 2006 - 9:27 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
he would need the entire wiring harness for a car with power windows stock..
when i did it i used 2 doors and the dash of a car with power windows stock
post Jun 6, 2006 - 8:23 PM
d-roCk
Joined May 25, '05
From Reno
wow that does seem a lot more complicated I looked on ebay for some power window kits and found some that are cheaper then the junkyard so I think Im just going to go with that! thanks i didn't even know they had those aftermark! I would have done it a long time ago!
Lo-Fi Version Time is now: June 25th, 2026 - 12:06 AM
