Jun 19, 2006 - 12:01 AM
Enthusiast ![]() ![]() Joined Dec 26, '05 From So Cal Currently Offline Reputation: 1 (100%) |
So i'm driving today and I notice that my turn signals are flashing about twice the normal rate. I just replaced the front turn signal bulbs with LED ones, could this have something to do with it? Is there any way of returning them to normal? I guess it's not really a big deal, but I would like them to be the way they were before, if possible.
Jun 19, 2006 - 12:26 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Long Beach Currently Offline Reputation: 1 (100%) |
im guessing that you prolly didnt use a resistor?
or did u change the relays? juss guessing -------------------- Is this good enuff 4 ya? :D
Jun 19, 2006 - 12:38 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
you might have to bridge a connection?
that's the way the car tells you that one of the bulbs is out. |
Jun 19, 2006 - 1:43 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
same thing happened to me when i changed the turn signals to LED. plus it didnt work and looked like crap from angles other than straight ahead. i decided to switch it back.
Jun 19, 2006 - 2:49 AM
Enthusiast ![]() ![]() ![]() Joined Jan 6, '06 From Oahu, Hawaii Currently Offline Reputation: 0 (0%) |
Okay, when you install LED bulbs, they use a lower wattage than do the regular stock ones. Therefore, you car "THINKS" that your bulb is out because less watts is going there. So your blinker blinking fast is a way to tell you that the bulb is burnt out. Solutions is i dunno.
Yet |
Jun 19, 2006 - 9:52 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
You need to put a ballast resistor across the 2 wires that goto the bulb holder. You will need 1 for each LED bulb.
Jun 19, 2006 - 11:32 AM
what is a ballast resistor and where can I get them?
Jun 19, 2006 - 2:49 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
go to autolumination.com...
i like em fast blinkers persanlly..but if a cop behinds u gets annoyed....jus say u got lexus bulbs in there..LoLs... -------------------- ![]() |
Jun 20, 2006 - 12:15 AM
I see what you're talking about. How many ohms of resistance should the resistors have?
Jun 20, 2006 - 12:35 AM
try this, and it will sound dumb but put the led in the other way. flip it and it should go back to normal blinking
Jun 20, 2006 - 1:35 AM
wtf lol that is wierd... welll post back if did it work?
This post has been edited by XS4lv1Truch0x: Jun 20, 2006 - 1:35 AM -------------------- Is this good enuff 4 ya? :D
Jun 20, 2006 - 2:36 AM
Turning the LED bulb around won't change anything, LED's have a positive and a negative side so the bulbs are designed to work regardelss which way around they are plugged it.
These are what you need, although this is a UK website I'm sure you'd be able to find an equivalent in the US. http://www.ultraleds.co.uk/product_info.ph...1042ceed6b03aa7 I have them on the front and rear indicators. |
Jun 20, 2006 - 8:44 AM
my experiences with leds is that if its not plugged on the right side they wont work right. not all led are user friendly. but for all this hassle for led turn signal bulbs, why not just buy some regulat 1157s and take back the leds and not worry about resistors and all that jazz
This post has been edited by LewFX: Jun 20, 2006 - 8:53 AM -------------------- ![]() |
Jun 20, 2006 - 1:19 PM
Enthusiast Joined Oct 4, '02 Currently Offline Reputation: 0 (0%) |
If you need load resistors to fix the blinking problem, you can buy them on ebay here:
http://stores.ebay.com/Velocity-LEDs http://stores.ebay.com/Velocity-LEDs_Load-...2QQftidZ2QQtZkm I'm sure you can get them elsewhere also. I haven't tried these, so I'm not endorsing this particular company. Let us know how you fix the problem. |
Jun 27, 2006 - 12:12 AM
Okay so I thought I'd try to get a few resistors at radioshack and hook them up myself today. I got some 10 ohm resistors for 99 cents and took them home. I found which wire to connect it to (since turn signal bulb is dual intensity). And it worked! But after only a few seconds the thing got REALLY HOT so I can't keep using it. At least now I know how many ohms of resistance I need, so I ordered some load resistors with 6 ohms of resistance that were made to carry that kind of current. I'll let you all know how it goes when I install them.
Jun 27, 2006 - 3:43 AM
they do get really hot mate, I have mounted mine to the crash bar behind the front bumper, and the rear ones to the inside bodywork behind the plastic panel in the boot (where it bends away from the plastic boot panel so it doesn't touch it and melt.) You don't have indicators on that long though so they shouldn't get stupidly hot.
| Lo-Fi Version | Time is now: September 16th, 2026 - 6:23 AM |
