Jun 19, 2006 - 12:45 AM
Enthusiast ![]() ![]() Joined Oct 10, '05 From San Diego Currently Offline Reputation: 2 (100%) |
I was driving to work today as I normally do almost everyday, when I accelerated at a traffic light. I shifted out of first and tried to put it in second when I first noticed the problem. It was very hard to put it in gear but as a spur of the moment thing i pushed it in. Then when I went to shift out of second it was very difficult and nearly impossible to put it in 3rd. I pulled over to a parking lot to check out the problem and decided it was the synchronization. I can drive it but in order to shift I have to match the rpm, speed, and gear.
any thoughts? This post has been edited by dlx742: Jun 19, 2006 - 1:07 AM |
Jun 19, 2006 - 12:49 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Long Beach Currently Offline Reputation: 1 (100%) |
QUOTE(dlx742 @ Jun 19, 2006 - 12:45 AM) [snapback]446179[/snapback] I was driving to work today as I normally do almost everyday, when I accelerated at a traffic light. I shifted out of first and tried to put it in second when I first noticed the problem. It was very hard to put it in gear but as a spur of the moment thing i pushed it in. Then when I went to shift out of second it was very difficult and nearly impossible to put it in 3rd. I pulled over to a parking lot to check out the problem and decided it was the synchronization. I can drive it but in order to shift I have to match the rpm, speed, and gear. any thoughts? its the syncro's, they are going bad, you are gona have to replace em or deal with it. -------------------- Is this good enuff 4 ya? :D
Jun 19, 2006 - 6:50 AM
odd for them to all go out like that.
check your fluid level. -------------------- Former Team 5SFTE pro member ;)
Jun 19, 2006 - 7:02 AM
This cannot be diagnosed over the internet. I had several shifting problems over the last couple years and the best advice I can tell you is to not summarily conclude that "its the syncros". Maybe it is, maybe it isn't. There are a ton of good threads about difficulty shifting and things you can try. Also, go look at mr2oc.com. They have some great threads too. Good luck.
Jun 19, 2006 - 2:33 PM
sounds like a problem with the clutch to me.
Jun 20, 2006 - 1:56 AM
Enthusiast ![]() Joined Jun 15, '06 From NJ Currently Offline Reputation: 1 (100%) |
chances are, more than one syncro wont fail at the exact same time, check
things like the clutch, linkage, slave and master cylinder first. |
Jun 20, 2006 - 1:57 AM
well usually it is the syncros if he has to match engine speed with car speed and ect. it could be that or somehting is mesing with the shifter cables.
Jun 20, 2006 - 3:57 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Bedford, TX Currently Offline Reputation: 11 (100%) |
so if my 1,2,3,4 works and not my 5th then its my syncro right? cuz if i put in 5th nothing.
-------------------- <--- I miss :'' ( |
Jun 20, 2006 - 4:10 PM
QUOTE(My2Celi @ Jun 20, 2006 - 3:57 PM) [snapback]446819[/snapback] so if my 1,2,3,4 works and not my 5th then its my syncro right? cuz if i put in 5th nothing. well that i dont know, i doubt its the syncro cause the syncro's are susposed to help make shifting easier. ps: hey look we joined 6gc the same day lol -------------------- Is this good enuff 4 ya? :D
Jun 20, 2006 - 7:36 PM
QUOTE(XS4lv1Truch0x @ Jun 20, 2006 - 4:10 PM) [snapback]446822[/snapback] QUOTE(My2Celi @ Jun 20, 2006 - 3:57 PM) [snapback]446819[/snapback] so if my 1,2,3,4 works and not my 5th then its my syncro right? cuz if i put in 5th nothing. well that i dont know, i doubt its the syncro cause the syncro's are susposed to help make shifting easier. ps: hey look we joined 6gc the same day lol actually the syncros do the actual shifting by locking the gear into place on the gear shaft, so if you have all all gears but one, its probably something related to that syncro/gear or possibly a linkage problem. |
Jun 20, 2006 - 8:16 PM
hehe nice well i gues ima try to rebuild this tranny. its only 200bucks to get a tranny kit its kinda unbelievable. well this place in dallas quoted me.
Jun 20, 2006 - 11:01 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
I have wiring under my shift boot and i was having difficulty shifting, and SPDT relay got lodged between my cables. Check for stupid stuff like that, you never know.
Jun 21, 2006 - 7:12 PM
definately check the linkage before you spend $200!
Jun 22, 2006 - 1:49 PM
took it to a friend's transmission shop and found out that i blew a spring out of the clutch disk and there was little to no clutch material left on the disc... so it was time for a new one. Now with the new clutch everything feels so much better. Shifting is smoother, the clutch throw feels good, and driving is so much better
Jun 25, 2006 - 7:05 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
QUOTE(My2Celi @ Jun 20, 2006 - 8:16 PM) [snapback]446929[/snapback] hehe nice well i gues ima try to rebuild this tranny. its only 200bucks to get a tranny kit its kinda unbelievable. well this place in dallas quoted me. If your good with tranny work go for it. I find that trannys are 10X harder than engines. |
Jun 25, 2006 - 9:26 AM
Enthusiast ![]() Joined Jun 14, '06 From bainbridge ga Currently Offline Reputation: 2 (100%) |
QUOTE(My2Celi @ Jun 20, 2006 - 3:57 PM) [snapback]446819[/snapback] so if my 1,2,3,4 works and not my 5th then its my syncro right? cuz if i put in 5th nothing. no that would be the 5th gear set if you go in 5th then nothing happens but a flare ( i worked for mantrans in tallahassee fla ) i sold alot of 5th sets not many for toy mostly nissan and jeep ax 5 and ax 15 |
Jun 25, 2006 - 9:30 AM
QUOTE(soulshadow @ Jun 25, 2006 - 7:05 AM) [snapback]448630[/snapback] QUOTE(My2Celi @ Jun 20, 2006 - 8:16 PM) [snapback]446929[/snapback] hehe nice well i gues ima try to rebuild this tranny. its only 200bucks to get a tranny kit its kinda unbelievable. well this place in dallas quoted me. If your good with tranny work go for it. I find that trannys are 10X harder than engines. thats a basic kit though bearings and rings but rest assured hes got other issues then just rings after a long while of use the sliders and hubs get worn and those aint cheap few years of experiance at mantrans of fla if your wondering |
Jun 25, 2006 - 9:57 PM
well today i found a 3sgte 91 mr2. i speak to the owner today and he said i can have the tranny. its a non lsd turbo tranny. the mount looks wierd, the shift cable part totally looks differnt. Would it go into my 5s? hes giving it to me for free.
| Lo-Fi Version | Time is now: August 28th, 2026 - 6:24 AM |
