Jun 20, 2006 - 3:39 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Long Beach Currently Offline Reputation: 1 (100%) |
okay check it out.
my engine check light came on, it dosent dissapear. car runs good, no abnormal behavior except for when its cold and i start the celi, white smoke comes out, no not cold in the morning even when its like 90 degrees, white smoke still comes out, it dosent smell like anything xcept water. but other than that, what else could be wrong? could it be the oxygen sensors? or could the valve seals be really messed up. where can i actually get my car scanned for codes for free? -------------------- Is this good enuff 4 ya? :D
Jun 20, 2006 - 4:38 PM
Enthusiast ![]() ![]() Joined Jan 17, '04 From Boston, MA Currently Offline Reputation: 1 (100%) |
QUOTE(XS4lv1Truch0x @ Jun 20, 2006 - 8:39 PM) [snapback]446814[/snapback] > okay check it out. > my engine check light came on, it dosent dissapear. > where can i actually get my car scanned for codes for free? U Can scan them yourslf. Find the diagnostic port and jump Terminals TE & E1. Read code, look up code. Do a serch for CEL or engine diagnostics. I always advise people t o Buy the manuals. They will save you big in the long run. Regards; |
Jun 20, 2006 - 5:33 PM
get in the zone, autozoneee...its a free loaner, some want down payment up front, others want Id and a CC, others will walk out with you and watch you!
Jun 20, 2006 - 5:36 PM
QUOTE(GMan @ Jun 20, 2006 - 4:38 PM) [snapback]446837[/snapback] QUOTE(XS4lv1Truch0x @ Jun 20, 2006 - 8:39 PM) [snapback]446814[/snapback] > okay check it out. > my engine check light came on, it dosent dissapear. > where can i actually get my car scanned for codes for free? U Can scan them yourslf. Find the diagnostic port and jump Terminals TE & E1. Read code, look up code. Do a serch for CEL or engine diagnostics. I always advise people t o Buy the manuals. They will save you big in the long run. Regards; i dont have a 94-95, it wont work on 96+ ima do what lewfx said. thanx -------------------- Is this good enuff 4 ya? :D
Jun 20, 2006 - 5:50 PM
AIC, O2 sensor or clogged fuel filter.
Jun 20, 2006 - 6:05 PM
Enthusiast ![]() Joined Jan 10, '06 From southern cal Currently Offline Reputation: 0 (0%) |
yeah autozone does it for free. just go ther
-------------------- boost fixes it all
Jun 21, 2006 - 3:29 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 12, '06 From Fresno CA Currently Offline Reputation: 1 (100%) |
do you have those desno/ngk Iridium sparks plugs?
Jun 21, 2006 - 9:03 AM
Enthusiast ![]() Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
QUOTE(pandakid @ Jun 21, 2006 - 3:29 AM) [snapback]447053[/snapback] do you have those desno/ngk Iridium sparks plugs? what does that have too do with it? i have denso iridiums and never had a problem -------------------- ![]() |
Jun 21, 2006 - 9:52 AM
it could be an IAT or ECT sensor issue, if either of those were bad and giving wrong readings you may not feel it when driving around, but you would feel it in the wallet with lower MPG. those sensors can be bad and not set a code. check the wires to them and the plugs for corrosion, then check the sensors electrical specs.
Jun 21, 2006 - 10:26 AM
Enthusiast Joined Jun 20, '06 From Lancashire England UK Currently Offline Reputation: 0 (0%) |
I'm no expert but white smoke out of the tail pipe always indicates water getting into the chambers. Check your coolant level, sounds to me as if you have a blowing gasket or cracked block/head. At first the symptoms are periodic as the crack or leak opens up as the engine temp drops then seals again as the presure and heat builds. Get it sorted now! if you leave it you are risking serious damage. The ECU prob picks the fault up due to the O2 readings going daft when your smoking.
Like i said though i'm no expert, just my opinion. Good luck Leigh.P |
Jun 21, 2006 - 9:41 PM
QUOTE(toyotatech @ Jun 21, 2006 - 9:03 AM) [snapback]447084[/snapback] QUOTE(pandakid @ Jun 21, 2006 - 3:29 AM) [snapback]447053[/snapback] do you have those desno/ngk Iridium sparks plugs? what does that have too do with it? i have denso iridiums and never had a problem my check light came on because of those. they say its too big of a spark for that motor. their ment for hi-performance motors, or assuming tubo or super charged -------------------- |
Jun 21, 2006 - 10:27 PM
QUOTE(pandakid @ Jun 21, 2006 - 9:41 PM) [snapback]447446[/snapback] my check light came on because of those. they say its too big of a spark for that motor. their ment for hi-performance motors, or assuming tubo or super charged "they" dont know what the 'fudge' they're talking about quite frankly. This post has been edited by Bitter: Jun 21, 2006 - 10:28 PM -------------------- |
Jun 22, 2006 - 8:10 AM
Enthusiast ![]() ![]() ![]() Joined Dec 28, '05 From USA Currently Offline Reputation: 0 (0%) |
white smoke even though its like 90 degrees outside? blown headgasket!! have it checked man! before things get worst!
Jun 23, 2006 - 9:12 AM
QUOTE(pandakid @ Jun 21, 2006 - 9:41 PM) [snapback]447446[/snapback] QUOTE(toyotatech @ Jun 21, 2006 - 9:03 AM) [snapback]447084[/snapback] QUOTE(pandakid @ Jun 21, 2006 - 3:29 AM) [snapback]447053[/snapback] do you have those desno/ngk Iridium sparks plugs? what does that have too do with it? i have denso iridiums and never had a problem my check light came on because of those. they say its too big of a spark for that motor. their ment for hi-performance motors, or assuming tubo or super charged QUOTE(Bitter @ Jun 21, 2006 - 10:27 PM) [snapback]447472[/snapback] QUOTE(pandakid @ Jun 21, 2006 - 9:41 PM) [snapback]447446[/snapback] my check light came on because of those. they say its too big of a spark for that motor. their ment for hi-performance motors, or assuming tubo or super charged "they" dont know what the 'fudge' they're talking about quite frankly. yeah they don't know what they are talking about, spark plugs won't set the CEL unless its picking up a miss fire, and they were not made for high performance engines, they were made to reduce the cost of maintenance, they will go for +100,000 miles. -------------------- ![]() |
Jun 25, 2006 - 1:41 AM
my automechanics teacher said that the valve seal guides were prolly going bad, its like steam but than after the car is done warming up, nothing comes out, no white smoke nothing.
car runs like it did when i got it, it dosent have any problems otehr than the white smoke. 10 dollars of gas get me like 60-80 miles on 89. but yeah i think ima go with lewfx and the air idle control. when i start the car, rpm's dip down to like 300-500 rpm, even on cold mornings. the rpm's wont kick up to 1100 rpm unless i rev it up to 3000 really quick. This post has been edited by XS4lv1Truch0x: Jun 25, 2006 - 1:43 AM -------------------- Is this good enuff 4 ya? :D
Jun 27, 2006 - 10:01 PM
okay you guys wont belive this.
the engine check light came on in the rav4! it has the same problem with the air idle control. except white smoke dont blow out of the exhaust. the engine is a 3sfe, i think it is the aic for both cars. -------------------- Is this good enuff 4 ya? :D
| Lo-Fi Version | Time is now: August 27th, 2026 - 5:33 PM |
