Jun 21, 2006 - 3:28 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Ok guys, im stuck, totaly stuck with my LHD conversion, im stuck with the damn steering gear, cuz the only one i can use is from GT (Euro Spec GT with 3SGE engine.....). This is cuz of the main underframe, and mounting points for the steering gear... I tryed all the way to use the AT200 Steering gear, but it is too short in lenght cuz of the longer steering arms what AT200 uses, and cuz they are straight. GT steering gear uses bent steering arms, and it is longer in lenght, and bents on the steering arms are to avoid hitting subframe....
I installed AT200 steering gear, but once i turn the Steering all the way to one side or another - there is only about 2mm gap between the subframe and steering arm... and i can not use GT steering arms cuz they are too short..... Only way is to make some sort of extensions for the GT steering Arms, but this way i will be risking to bend / brake the extension, cuz it will be weak point.... All i need to know - is there a difference between US GT and Euros GT steering gears, and is there a difference in US GT and AT suspension.... IF some one could post a pics of how the US GT steering gear looks, and if some one could messure the Lenght of the steering gear without the Steering arms - i would hudgly apreciate it... Thanks, Romas -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
doGGy Need Help on Steering gear Jun 21, 2006 - 3:28 PM
doGGy huh, anyone? C'mon guys who have parted out ca... Jun 22, 2006 - 1:27 PM
WannabeGT4 I'd love to help you Romas but my engine is st... Jun 22, 2006 - 4:15 PM
doGGy QUOTE(WannabeGT4 @ Jun 22, 2006 - 2... Jun 22, 2006 - 5:05 PM
Batman722 this is all I have Romas.... Jun 22, 2006 - 6:07 PM
doGGy Dustin - can you check on the steering arms, are t... Jun 22, 2006 - 6:35 PM
Batman722 strait
there are 3 on ebay right now
http://cgi.... Jun 22, 2006 - 6:45 PM
Batman722 here are some pics from first a USDM rack
and... Jun 22, 2006 - 6:55 PM
doGGy Dustin - are the first one pictured is from USDM G... Jun 22, 2006 - 7:45 PM
Batman722 the first 2 were USDM, the last was LHD st202, the... Jun 22, 2006 - 10:28 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 15th, 2026 - 6:06 PM |
