> st205 3rd gen vs. st185 2nd gen axles
post Jun 22, 2006 - 3:07 PM
urbandork
Joined Jul 16, '04
From Los Angeles
Is there a diffrence?
also whats the spindel like on the e153 set up verses that on an all trac/gt4
post Jun 22, 2006 - 4:32 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(urbandork @ Jun 22, 2006 - 1:07 PM) [snapback]447696[/snapback]
Spindles are the same (rather, the outer portion is the same) for the ST18x and ST20x. The hubs do not need to be changed no mater what axle you have (not counting ABS vs. non-ABS). (even the ST205 axles slide and seat fine in my '90 Camry hubs, though they don't work for anything else)
ST185 axles have the bolts similar to the E153 axles, so they can be easily made into hybrid axles. ST205 axles are one piece and cannot be used in the same way.
-Cahrlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
Lo-Fi Version Time is now: May 18th, 2026 - 7:11 AM
