> Disable Interior Lights, Door or Hatch is open
post Jun 24, 2006 - 12:23 PM
Jaws4God
Joined Mar 27, '04
Hey everyone,
For car meets and shows, i'd like to leave my doors open and especially my hatch when I get my new audio system finished this week. But I don't want all my interior lights to be on. Does anyone know of an easy solution for that?
I'm wondering if I can just tap into a wire that triggers it all and just hook up a switch. If that can be done, any know where that is?
Thanks!
post Jun 24, 2006 - 12:45 PM
Griff
Joined May 25, '06
From South Carolina
other day i took off the door panel and i know there is a group of wires that is to that light...but i dunno if u want them ever...but if u never really wanted them, disconnect that wire i would guess...would guess...meaning i not really sure how easy (if it controls somthing else)/pratical it is.
post Jun 24, 2006 - 12:50 PM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
Isn't there a switch on the top of the car (where the mid internal light is) that says: on / door / off?
When that's on off, no lights go on when the doors are opened. Haven't checked the trunk tho.
post Jun 24, 2006 - 2:16 PM
Griff
Joined May 25, '06
From South Carolina
i know that works on the main light in cabin, but does that work for door lights?
post Jun 25, 2006 - 8:20 PM
JFrost9
Joined Aug 27, '05
From Texas
If its a one time even, then i would simply take out the bulbs in the doors, and then turn the switch to off on all the others... As far as the wires go, im not sure.
JFrost9
Joined Aug 27, '05
From Texas
oops
This post has been edited by JFrost9: Jun 25, 2006 - 8:20 PM
post Jun 25, 2006 - 8:53 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
pull the "dome" 10A fuse under the hood, that should do the trick for ya
This post has been edited by K-ESD: Jun 25, 2006 - 8:53 PM
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jun 27, 2006 - 9:28 AM
Jaws4God
Joined Mar 27, '04
QUOTE(K-ESD @ Jun 26, 2006 - 1:53 AM) [snapback]448818[/snapback]
will that pull power from the dome light and door lights?
post Jun 27, 2006 - 11:10 AM
K-ESD
Joined May 5, '05
QUOTE(Jaws4God @ Jun 27, 2006 - 11:28 AM) [snapback]449464[/snapback]
it should, it will disable all interior lights, dash lights, dome, doors, trunk light, etc...
post Jun 27, 2006 - 11:24 AM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
If you take off the back speaker cover you should see some wires for your door. You can unhook that and then it won't know if the door is open or closed. You can also put I switch there if you really wanted to. The only thing with disconnecting the wires is that your alarm wont work or at least that how it was with mine.
where the crappy arrow is. I don't know but thats what I did.
-Brad
01 a4: daily
post Jun 28, 2006 - 6:25 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
you could switch all the bulbs to led ones mate, they won't hardly draw any current if your concerned about wearing out the battery. I'm about to do that with mine, well on the door markers anyway as other interior lights have switches.
post Jun 28, 2006 - 12:12 PM
Conwa
Joined Nov 5, '05
Just kill the door switch from the one u open,
or keep it pushed in with tape or something.
This post has been edited by Conwa: Jun 28, 2006 - 12:15 PM
post Jul 6, 2006 - 1:18 AM
Magical_Celica_g...
Joined Feb 23, '03
From Toronto, Ont. Canada
QUOTE(C3L1CA @ Jun 27, 2006 - 9:24 AM) [snapback]449515[/snapback]
THats what i did it works great
post Jul 8, 2006 - 8:13 AM
K-ESD
Joined May 5, '05
QUOTE(K-ESD @ Jun 25, 2006 - 10:53 PM) [snapback]448818[/snapback]
why would anyone bother taking the entire interior appart just to disable some of the interior lights for a show?
like i said above, pull the 10A "Dome" fuse, thats it.
Have a look at what it does
http://www.celicatech.com/vfewdsou/1995/95...ic/interior.pdf
post Jul 8, 2006 - 11:20 PM
Jaws4God
Joined Mar 27, '04
I pulled the fuse and that did what i needed... thank you all!! So much easier than running a switch!
Lo-Fi Version Time is now: June 26th, 2026 - 9:40 AM
