Jun 28, 2006 - 1:14 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
So my sis in laws older celica has an issue with the ground wire igniting (the chasis ground wire), so im thinkin the ground to the block is faulty (grounding out thru chasis only doesnt provide adequate grounding source so it burns up?) sound right to anyone else or any other posibilities i should explore? thanks in advance to any advice
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." ![]() |
Jun 28, 2006 - 4:33 PM
run some 2ndary grounds from clean metal to clean metal from engine to body. basically wherever you see a ground, run a new clean one next to it.
| Lo-Fi Version | Time is now: May 20th, 2026 - 9:00 AM |
