Jul 1, 2006 - 1:00 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
how do you remove the interior trim piece that is right beside the clutch pedal?
is it all held in with clips? if yes, where are the clips positioned? do i needa remove any other part to remove that part? This post has been edited by elvasoshexai: Jul 1, 2006 - 1:13 AM -------------------- |
Jul 1, 2006 - 1:53 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 11, '04 From Oakdale, MN Currently Offline Reputation: 3 (100%) |
If you are talking about the little triangle piece then it has a little black plastic nut that screws into the floor right by the clutch pedal. Twists the plastic nut off then you should be able to pull it out. The rest of the interior pieces for the most part just pull out if you aren't talking about what I'm talking about.
-------------------- -Brad
95 GSX: Stock motor, fp3065, corn = 10.9 @ 140 06 R6: Strappd and sprocketed = 11.0 @ 127 01 a4: daily 94 Celica: totaled - someday have another celica thats fast instead of looks cool |
Jul 1, 2006 - 9:44 AM
Enthusiast ![]() ![]() ![]() Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) |
kick panel. you neet to remode the small pieces tha go up thr pinch weld on the doorjamb area, and i think the sill plate. both of those just pull oout/off
This post has been edited by b1gr3d: Jul 1, 2006 - 9:45 AM -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Jul 1, 2006 - 11:04 AM
QUOTE(b1gr3d @ Jul 1, 2006 - 10:44 AM) [snapback]450973[/snapback] kick panel. you neet to remode the small pieces tha go up thr pinch weld on the doorjamb area, and i think the sill plate. both of those just pull oout/off do you mean i need to remove the 2 long thin pieces that the door covers when it closes? then after follow c3lica's instructions? -------------------- |
Jul 1, 2006 - 1:15 PM
QUOTE(elvasoshexai @ Jul 1, 2006 - 10:04 AM) [snapback]450991[/snapback] QUOTE(b1gr3d @ Jul 1, 2006 - 10:44 AM) [snapback]450973[/snapback] kick panel. you neet to remode the small pieces tha go up thr pinch weld on the doorjamb area, and i think the sill plate. both of those just pull oout/off do you mean i need to remove the 2 long thin pieces that the door covers when it closes? then after follow c3lica's instructions? yes -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
| Lo-Fi Version | Time is now: August 11th, 2026 - 10:00 AM |
