> CEL 47 on GEN3 ECU, what the hell is "secondary TPS" ???
post Jul 2, 2006 - 2:14 PM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
i got an error code 47 on my 95 sw20 gen3 ecu
its not even mentioned in BGB
this is the only result of my search:
http://www.mr2oc.com/showthread.php?t=1023...;highlight=code
Please advise!
This post has been edited by CilverSeliST205: Sep 27, 2006 - 2:36 PM
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
Replies (1 - 9)
post Jul 3, 2006 - 8:51 AM
CilverSeliST205
Joined Nov 3, '05
post Jul 3, 2006 - 5:14 PM
jgreening
Joined Jan 17, '04
From Illinois
Not alot of Gen III'ers here. You might want to try gt4oc.com or another one of the gt4 forums across the pond.
post Jul 4, 2006 - 2:48 AM
CilverSeliST205
Joined Nov 3, '05
QUOTE(jgreening @ Jul 3, 2006 - 6:14 PM) [snapback]451730[/snapback]
gotta pay to speak on gt4oc.com kindasad.gif but I think $20 is worth it (toyota forums rock)
post Jul 6, 2006 - 11:09 AM
CilverSeliST205
Joined Nov 3, '05
QUOTE(CilverSeliST205 @ Jul 4, 2006 - 2:48 AM) [snapback]451890[/snapback]
Wow I just payed almost $40 for a YEAR membership to gt4oc.... well for you folks with gen3, if you got some problem that you cant solve/find answer to anywhere let me know and i will seek help for you on gt4oc
post Jul 6, 2006 - 3:43 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
thanx dude, wish we could've help but most ppl have the 2nd gen 3sgte.
post Sep 27, 2006 - 2:34 PM
CilverSeliST205
Joined Nov 3, '05
So I continued to research my cel issue and today I came across this onmr2oc forums (quote on the bottom)
and this page lists check engine light codes for gen3 3sgte: http://www.ayrpark.plus.com/errorcodes/normal.htm
code 47 is listed as "Secondary throttle position sensor", and described with this: "[VTA1, VC, IDL2, E2]
Whenever a short circuit or a circuit detachment in the secondary throttle position sensor is detected for over 0.5 seconds." in area of: "* Wirings and connectors (secondary throttle position systems)
* Secondary throttle position sensor
* ECU
Does anyone have any idea as to what secondary TPS is and how to test for its functionality ??????
found this
http://www.ayrpark.plus.com/errorcodes.html
if you go on the rev3 turbo bit, youll see vta2 on the error code 47.....now i have a ecu error code 47, but i beleive many many rev3 owners have this error as well as all rev1/2 to rev3 conversion folk.....
any more ideas??
i cant find anywhere to test for the "secondary" TPS.....the BGB only lists the main TPS with outputs of vc, ta, idl and e2
instead of the vta2, vc, idl2 and e2 thats listed on that page for the "secondary" tps..........
post Sep 27, 2006 - 5:07 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Sounds like its an issue with the idle switch (the throttle closed switch). Check each of the pins you mentioned there in your last post at the ECU to make sure the correct signal is getting there. You can check it with the key in the 'on' position and the motor off (so you can go full throttle 'n stuff without killing the motor!).
Is your throttle held open at all by the throttle cable? (I had to modify mine a bit to get it to allow the throttle plate to close all the way)
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Sep 27, 2006 - 5:15 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Is it the IAC valve? I would just spray the whole TB with CRC and see what that does.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Sep 28, 2006 - 8:04 AM
CilverSeliST205
Joined Nov 3, '05
thanks for advice guys, I will be messing around with crc and multimeter after work today, hopefully Ill figure something out
Lo-Fi Version Time is now: June 10th, 2026 - 3:35 AM
