Jul 6, 2006 - 7:32 PM
Enthusiast ![]() Joined Dec 11, '05 From MN, Rochester Currently Offline Reputation: 1 (100%) |
I'm looking for a intercooler for my 3sgte swap anyone recommend anything? I have 700$
Jul 6, 2006 - 7:41 PM
pshh if you have 700$ on just an intercooler get a SPEARCO its the best one out there IMO and flows better then greddy!
Jul 6, 2006 - 9:19 PM
i have a spearco ... seems to work well for me. it was only about 300 on ebay.
Jul 7, 2006 - 12:11 PM
my next intercooler. One sided to keep the intercooling pipes away from the hot side of the exhaust / manifold and should make for a better more efficientt route. bar and plate Core Dimensions: 600mm X 300mm X 76mm Overall length of 770mm All TIG Welded 6061 Aluminum, polished end tanks 100% Vacuum Brazed Core High Efficiency Bar & Plate Construction 2.5inch Inlet and Outlet Max Recommended PSI: 45psi Low pressure drop w/ only 0.2psi at 15psi of boost Tested CFM: 1020 CFM so the ebay auction says i doubt one brands Bar and plate cools more than another brand so. i mean how can you screw up sheets of folded aluminum. under $200 for it also. Heres a link. -------------------- |
Jul 7, 2006 - 12:55 PM
why would you want a one sided one? its going to be tricky as hell to route the piping all to one side.
if you want to keep your piping cool from the exhaust manifold, just use some heat wrap. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 7, 2006 - 2:11 PM
didn't you ever read the thing on MR2oc about heat wrap...its bad from wat i gathered...
one sided is the way i'm going to go to john its a great idea and the pipes are actually really easy to run... |
Jul 8, 2006 - 2:42 PM
QUOTE(playr158 @ Jul 7, 2006 - 3:11 PM) [snapback]453106[/snapback] didn't you ever read the thing on MR2oc about heat wrap...its bad from wat i gathered... one sided is the way i'm going to go to john its a great idea and the pipes are actually really easy to run... sweet. yeah the pipes wont be an issue im also relocating the bat to the trunk -------------------- |
Jul 8, 2006 - 7:33 PM
QUOTE(playr158 @ Jul 7, 2006 - 3:11 PM) [snapback]453106[/snapback] didn't you ever read the thing on MR2oc about heat wrap...its bad from wat i gathered... one sided is the way i'm going to go to john its a great idea and the pipes are actually really easy to run... heat wrap isint good or bad. its all in how or where you use it. i still dont understand the point of going to a one sided setup. if your looking for something clean and short, clock the trubo, then go from the turbo to the drivers side down, and from the throttle body to the passengers side. it would be a clean and simple setup. This post has been edited by lagos: Jul 8, 2006 - 8:24 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 8, 2006 - 9:03 PM
QUOTE i still dont understand the point of going to a one sided setup. if your looking for something clean and short, clock the trubo, then go from the turbo to the drivers side down, and from the throttle body to the passengers side. it would be a clean and simple setup. yea, but, doing it that way, your really not shortening the piping at all. -------------------- Former Team 5SFTE pro member ;)
Jul 8, 2006 - 9:08 PM
QUOTE(presure2 @ Jul 8, 2006 - 10:03 PM) [snapback]453523[/snapback] QUOTE i still dont understand the point of going to a one sided setup. if your looking for something clean and short, clock the trubo, then go from the turbo to the drivers side down, and from the throttle body to the passengers side. it would be a clean and simple setup. yea, but, doing it that way, your really not shortening the piping at all. yeah but, neither would having the piping all run to one side. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 8, 2006 - 11:21 PM
you don't even need to relocate the battery just run the pipe up the fender in the same path as your stock intake
(i also plan for the 1 sided IC and piping run through the fender for reasons 1) cleanness of engine bay(including clocked turbo) and 2) side feed intake manifold) This post has been edited by playr158: Jul 8, 2006 - 11:22 PM |
Jul 8, 2006 - 11:44 PM
Enthusiast ![]() ![]() ![]() Joined Dec 28, '05 From USA Currently Offline Reputation: 0 (0%) |
QUOTE(lagos @ Jul 8, 2006 - 7:33 PM) [snapback]453511[/snapback] heat wrap isint good or bad. its all in how or where you use it. ah, finally, someone who understands, you should talk to the guy in the other thread who wants to heat wrap his headers |
Aug 1, 2006 - 9:40 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
guys, i am looking at an intercooler for a great price, but i don't know about sizes.
# Polished Finish Aluminum. # All TIG Welded 6061 Aluminum. # Overall Size: 32" x 12" x 3" # Inlet/Outlet: 3" # Max Recommended PSI: 30psi # Pressure Drop at under 10% that too big? also available # Overall Size: 28" x 9" x 2.5" # Inlet/Outlet: 2" This post has been edited by FallenHero: Aug 1, 2006 - 9:45 AM |
Aug 1, 2006 - 1:13 PM
![]() Enthusiast ![]() ![]() Joined Nov 3, '05 From Chicago Suburbs Currently Offline Reputation: 1 (100%) |
QUOTE(ToysRfast @ Jul 6, 2006 - 7:32 PM) [snapback]452792[/snapback] I'm looking for a intercooler for my 3sgte swap anyone recommend anything? I have 700$ consider getting water-air IC, beefy pump, monster heat exhanger and 3-4 gallon tank. Less piping than any FMIC and possibly better efficiency... heat shield it if necessary, mix up your water wetter and your good to go -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
Aug 1, 2006 - 3:02 PM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
i have your piping kit already to go! see the buying selling section. you might find some more intercooler info there too.. *hint hint*
Aug 1, 2006 - 3:45 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
QUOTE(zipstrips @ Aug 1, 2006 - 4:02 PM) [snapback]464138[/snapback] i have your piping kit already to go! see the buying selling section. you might find some more intercooler info there too.. *hint hint* LOL real slick dude..! |
Aug 1, 2006 - 4:41 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 30, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
You can ask for the GReddy Spec-M Intercooler (New 2-Layer Intercooler by Greddy).You can buy the Kit for the Nissan S15 which is the cheaper (beacuse its including just few pipes in the kit) and go for custom piping using that core.Average price for that kit i think its around 50,000Yen.
Aug 23, 2006 - 9:35 PM
QUOTE(x_itchy_b_x @ Jul 7, 2006 - 1:11 PM) [snapback]453060[/snapback] my next intercooler. One sided to keep the intercooling pipes away from the hot side of the exhaust / manifold and should make for a better more efficientt route. bar and plate Core Dimensions: 600mm X 300mm X 76mm Overall length of 770mm All TIG Welded 6061 Aluminum, polished end tanks 100% Vacuum Brazed Core High Efficiency Bar & Plate Construction 2.5inch Inlet and Outlet Max Recommended PSI: 45psi Low pressure drop w/ only 0.2psi at 15psi of boost Tested CFM: 1020 CFM so the ebay auction says i doubt one brands Bar and plate cools more than another brand so. i mean how can you screw up sheets of folded aluminum. under $200 for it also. Heres a link. ![]() looks like its gunna fit.. -------------------- |
Aug 23, 2006 - 9:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
no crash bar?
anyways for 700$ id go the stock w2a setup.. quicker spool, cleaner engine bay, more oem. |
**** the crash bar
| Lo-Fi Version | Time is now: September 1st, 2026 - 6:30 AM |
