> Idle Rev
post Jul 9, 2006 - 9:17 PM
o0black0o
Joined Jul 14, '05
From Spring, Texas
I don't know what this could be but I have a few ideas. I was wondering what any of yall may think it could be.
My car normal temp in idle revs itself 100rpms back and fowarth. Anyone got any ideas?
post Jul 9, 2006 - 10:37 PM
phonex98
Joined Mar 25, '06
Distributer and/or spark plugs replacement. Worked for me smile.gif
----- '94 ST hatch --- Yellow -----
post Jul 9, 2006 - 10:42 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
It could be so many things. Mine does/did that off and on for a long time. My last car did it too. It hasn't done it in a while, but I'm kind of just waiting on it. I replaced my intire ignition system, but I fear it could just be a banade on the real problem. I think it's a vac issue. I hate vac lines.
Live Free, Be Happy
post Jul 9, 2006 - 10:59 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
check the IAC coil specs.
post Jul 9, 2006 - 11:17 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
vacum leak, cap n rotor, IAC, o2, sticky throttle cable... etc theres a # of things
post Jul 10, 2006 - 5:53 AM
IAC valve.
post Jul 10, 2006 - 11:48 AM
MacBain
Joined Jul 10, '06
From Oslo, Norway
I'm having the same problem as you. Idle rpm jumps between 750-1000.
I have checked all the vacum lines, cap n rotor, I've also flushed the radiator to make sure there's no air trapped in the system.
I think the problem is the IAC valve. Going to give it a good wash with some carburator cleaner and see if that helps.
post Jul 10, 2006 - 12:06 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
if anyone needs a IAC valve, ive got 2 available.
post Jul 17, 2006 - 9:14 AM
o0black0o
Joined Jul 14, '05
From Spring, Texas
How much do the IAC Vayles run 4?
Sparks and Rotor/Cap should be ok. I changed them not to long ago. Yet I'll check them just 2 be safe. I think its ether the IAC or the vaccum. Car has 167k on it so its bound to be many things.
This post has been edited by o0black0o: Jul 17, 2006 - 9:17 AM
post Jul 17, 2006 - 11:18 AM
MacBain
Joined Jul 10, '06
From Oslo, Norway
I've fixed the problem on my car, it was the IAC valve. I didn't have to replace it, I just ajusted it so it would close properly. To do this I removed the two screws on the back of the IAC valve and moved the position of the metal plate.
Now the car idles perfectly. The Rpm on coldstarts has also gone down from 2000rpm to 1300rpm.
P.S I have the 3SGE engine, so I don't know if it's the the same on your car.
This post has been edited by MacBain: Jul 17, 2006 - 11:18 AM
post Jul 17, 2006 - 5:18 PM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
wheres the idle air control at?
i need to do that to mine! mines idles low like urs except its like 500 rpm.
Is this good enuff 4 ya? :D
post Jul 17, 2006 - 5:40 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
it should be right on the throttle body.
post Jul 17, 2006 - 6:33 PM
o0black0o
Joined Jul 14, '05
From Spring, Texas
I have a 7afe. I know how to clean it. I just have to get the carbon cleaner and time to do it.
Mine doesn't rev big just like 100rpms back and fowarth.
I can hear it in the exaust also. Thats how I mainly noticed it at first.
This post has been edited by o0black0o: Jul 17, 2006 - 6:34 PM
post Jul 18, 2006 - 6:47 AM
MacBain
Joined Jul 10, '06
From Oslo, Norway
In my case, cleaning it wasn't enough. I had to adjust it.
You can check if the valve opens and shuts properly if you connect it to a 12v source (car battery).
Check out the BGB on how to test it.
post Jul 18, 2006 - 2:24 PM
o0black0o
Joined Jul 14, '05
From Spring, Texas
thanks ill check it out
post Jul 28, 2006 - 10:26 AM
95gtschick
Joined Sep 18, '04
From Manitoba, Canada
what should the idle be at when running normally? mine's usually at 700rpm's and it's consistent. is that normal?
post Aug 2, 2006 - 11:29 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
yeah I think 750 or so is perfect, so your good
This post has been edited by nightryder: Aug 2, 2006 - 11:30 PM
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
Lo-Fi Version Time is now: June 22nd, 2026 - 8:40 PM
