> Grounding for gauge wiring, Installing gauges and I'm looking to ground!
post Jul 13, 2006 - 7:23 PM
LeonStryfe
Joined Mar 28, '06
From Brooklyn, New York
I'm installing new gauges and lights and I'm almost done. However, I need to know: What can I use to ground wires within the dash, if possible? And if it is possible, exactly what should I do with it?
I tap the dimmer switch power. The solid green wire in the dimmer harness. I need to find to ground my wire. would it work with the white/black wire in the dimmer switch?
This post has been edited by LeonStryfe: Jul 13, 2006 - 7:39 PM
Replies (1 - 1)
post Jul 13, 2006 - 11:06 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
remove the side steps..and jus drill in anything with a selftapping scrww..and voila,....ground!!!
Lo-Fi Version Time is now: May 10th, 2026 - 2:18 PM
