> Engine Codes, car is not boosting
post Jul 16, 2006 - 11:20 AM
GMoney
Joined Jan 18, '06
From St.lucia
hey can anyone help me with a site that has the engine error codes for the 3sgte frown.gif
post Jul 16, 2006 - 12:41 PM
celicatech BGB online archive
post Jul 16, 2006 - 2:23 PM
here:
http://celicatech.com/forums/showthread.php?t=10155
3sgte CEL Error Code List
11 - ECU Momentary interrupt in power Check relays, IG switch
12 - RPM No "G" signal to ECU for 2 sec after crank Starting related, check distributor, starter
13 - RPM No "NE" signal to ECU above 1000 RPM Check distributor
14 - IGN No "IGF" signal to ECU 8-11 times Check Igniter, ignition coil
21 - O2 Detection of oxygen sensor detoriation Check oxygen sensor
21 - O2 Open or short circuit in o2 sensor heater Check oxygen sensor
22 - WTR Open or short in Water Temp Sensor Check Water Temp Sensor
24 - AIR Open or short circuit in Air Temp Sensor Check Air Temp Sensor
25 - O2 Excessive Lean Air Fuel Ratio Check o2 sensor and fuel system
26 - O2 Excessive Rich Air Fuel Ratio Check o2 sensor and fuel system
31 - AFM Open circuit or short in VC signal Test or replace Air flow Meter
32 - AFM Open circuit or short in E2 signal Test or replace Air flow Meter
34 - TRB Fuel cut due to excessive turbo pressure Check Wastegate Hose, Test Pressure Sensor
35 - TRB Open or short circuit in Pressure Sensor Test Turbo Pressure Sensor
41 - TPS Open or short circuit in VTA signal Test Throttle Position Sensor
42 - SPD No "SPD" signal over 8 seconds driving Check Vehicle Speed Sensor
43 - STA No "STA" signal over 800 RPM starting Check Ignition Switch
51 - IDL No "IDL" or A/C signal during testing Check TPS, A/C switch, Accelerator cable
52 - KNK Open or short circuit in Knock Sensor Check for broken/brittle wire, Replace Sensor
54 - INT Intercooler Coolant Low or Pump Failure Replace Water Level Sensor, Test IC W. Pump
71 - EGR EGR gas temp below acceptable level Check EGR system, (Valve/VSV/Hose/Tem
This post has been edited by lagos: Jul 16, 2006 - 2:23 PM
post Jul 16, 2006 - 2:33 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Hey i got code 32 on my Alltrac when i ran the codes. I dont think my AFM is bad becuase they said if it was, the car would shut off after about 5 seconds after starting the car. But mine "runs", well it idles VERY poorly. And i cant rev it past 4k RPMS. the idle is really low as well, like LOW 250rpms, sounds like the car is about to die but keeps saving itself. I was just wondering if that engine code 32 could cause this problem. Sorry to jack the thread. frown.gif
post Jul 17, 2006 - 7:45 AM
QUOTE(MaskedMan @ Jul 16, 2006 - 3:33 PM) [snapback]456877[/snapback]
yes.
Lo-Fi Version Time is now: August 20th, 2026 - 7:02 PM
