> 3sge and 3sgte pistons, would they fit into a 5sfe?
post Jul 17, 2006 - 4:58 PM
Valo666
Joined May 15, '05
From Toronto
well..title is pretty self explenatory. I found out today that i can order ALOT of engine internals for toyota cars. Like i can get every peice of the valve train except for cams and the actuall head its self. Any ways, i checked and i can get pistons for a 3sgte for like $45 each. will they fit?
post Jul 17, 2006 - 5:10 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
to the best of my knowledge they would fit if you got different piston rings for it, since the 3s is a 2.0ltr and the 5s is a 2.2ltr.
post Jul 17, 2006 - 6:50 PM
no.
post Jul 17, 2006 - 6:59 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
ok i take back what i said then. i was just in the mentallity that since people can fit 4agze pistons into a 7age which is .2 ltrs bigger that it could possibly work the same in this situation. sorry for the mistake.
This post has been edited by MaskedMan: Jul 17, 2006 - 7:01 PM
post Jul 18, 2006 - 10:38 AM
Valo666
Joined May 15, '05
From Toronto
just looked through the cataloge and saw the bore size is alot bigger on the 5s, nvm.
post Jul 18, 2006 - 9:29 PM
puretone
Joined Jun 18, '06
From Aruba
best thing to do is measure the bore anyways....because you will want to hone your sleeves if you are gonna put new pistons in.
I got the BEAMS 3SGE Redtop, im thinking of turboing it, and i will be putting in low compression pistons, and honing to fit the new arias pistons in.....
Toyo'd, Eibach'd, Kayaba'd & BEAMS'd :D
Lo-Fi Version Time is now: August 25th, 2026 - 9:58 AM
