Jul 17, 2006 - 10:22 PM
ok... so my AC hasnt worked since the swap and i figure now is a good time to wire that crap up. so i have my harness apart and im trying to look at the wiring diagrams to figure out a few things. seems like i need some help.
"ac amplifier" in the diagrams means the main AC compressor, correct? on it, is a plug called A8 (looking at the 5sfe diagrams). the harness goes from there to a plug called IM1 and then 3 wires go to the ECU's 1st plug. where is IM1 located ? is it the white, 5 wire plug that goes from the 3s hanress, and plugs in right behind the glove box? This post has been edited by lagos: Jul 29, 2006 - 9:02 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
lagos How to make AC work with your swap Jul 17, 2006 - 10:22 PM
lagos i finally found my wiring book. IM1 seems to be th... Jul 18, 2006 - 3:00 AM
MaskedMan I think the plug is called A4 (A/C magnetic clutch... Jul 18, 2006 - 3:11 AM
lagos yeah, your right. on a 6th gen they call it A2 an... Jul 18, 2006 - 3:33 AM
lagos ok ... i think i figured most of it out...
on t... Jul 18, 2006 - 4:02 AM
MaskedMan well the Black-White wire from A4 goes to a splice... Jul 18, 2006 - 4:33 AM
lagos awesome! airconditioned car, here i come... Jul 18, 2006 - 10:41 AM
MaskedMan oh sorry i forgot to put where the 4th pin of the ... Jul 18, 2006 - 12:07 PM
lagos awesome, you rock Jul 18, 2006 - 12:31 PM
lagos chrisD from ctech was able to hook me up with the ... Jul 18, 2006 - 1:33 PM
MaskedMan oo nice, I was just going off my own alltrac, and ... Jul 18, 2006 - 1:52 PM
lagos alright.... one more quick question. seems the AC... Jul 18, 2006 - 9:05 PM
MaskedMan hmm... ok 2 wires should be to activate the magnet... Jul 18, 2006 - 9:17 PM
lagos cool ... if you find out all the functions of the ... Jul 18, 2006 - 10:12 PM
MaskedMan OOO nice, your 98 compressor should be better anyw... Jul 18, 2006 - 10:22 PM
lagos QUOTEif you use your stock compressor, cant you ju... Jul 18, 2006 - 10:37 PM
lagos ok.. i figured out the functions of the 3 wires th... Jul 19, 2006 - 12:47 AM
WannabeGT4 QUOTE(lagos @ Jul 19, 2006 - 12:47 A... Jul 19, 2006 - 10:25 AM
MaskedMan haha nice, i was just about to give you the same i... Jul 19, 2006 - 9:34 AM
phattyduck I'm also curious as to why there was any rewir... Jul 19, 2006 - 12:40 PM
lagos QUOTE(phattyduck @ Jul 19, 2006 - 1... Jul 19, 2006 - 1:00 PM
phattyduck QUOTE(lagos @ Jul 19, 2006 - 11:00 A... Jul 19, 2006 - 4:01 PM
lagos so i put everything back togther today to test out... Jul 19, 2006 - 9:37 PM
lagos "Pressure Switch
The pressure switch is threa... Jul 20, 2006 - 1:15 AM
MaskedMan maybe. this is becuase the oil, is mixed in with ... Jul 21, 2006 - 4:22 AM
lagos yeah... i think this is whats going on.
i traced... Jul 21, 2006 - 9:16 AM
Dr_Tweak You could do it for a couple seconds okay, just do... Jul 21, 2006 - 9:57 AM
lagos QUOTE(Dr_Tweak @ Jul 21, 2006 - 10:5... Jul 21, 2006 - 10:07 AM
lagos plug IM1 (female) 6th gen plug that goes behind th... Jul 21, 2006 - 10:19 AM
Aaagogo so this will be the working wiring configuration
... Jul 21, 2006 - 9:06 PM
Dr_Tweak Just off the top of my head, it does look like you... Jul 21, 2006 - 10:30 AM
lagos QUOTE(Dr_Tweak @ Jul 21, 2006 - 11:3... Jul 21, 2006 - 10:35 AM
Dr_Tweak You don't actually *have* to have it vacuumed.... Jul 21, 2006 - 12:26 PM
WannabeGT4 QUOTE(Dr_Tweak @ Jul 21, 2006 - 12:2... Jul 21, 2006 - 2:50 PM
lagos IT WORKS!
i got another bottle of R134 beca... Jul 21, 2006 - 4:30 PM
Fastbird Lagos, with everything working, does your car idle... Jul 21, 2006 - 4:54 PM
lagos QUOTE(Fastbird @ Jul 21, 2006 - 5:54... Jul 21, 2006 - 5:09 PM
lagos i did a little ghetto bleeding . fill the low sid... Jul 21, 2006 - 9:01 PM
MaskedMan QUOTE(lagos @ Jul 21, 2006 - 7:01 PM... Jul 21, 2006 - 9:57 PM
lagos yep thats how you wire it up.
you just need to lo... Jul 21, 2006 - 9:10 PM
lagos whats the deal with the AC idle up valve? i see i... Jul 22, 2006 - 12:46 AM
WannabeGT4 http://www.celicatech.com/vfewdsou/1995/95...ic/en... Jul 22, 2006 - 1:15 AM
lagos ah ha! nice find.
i was looking at the AC s... Jul 22, 2006 - 1:46 AM
Dr_Tweak QUOTE(lagos @ Jul 22, 2006 - 6:46 AM... Jul 22, 2006 - 6:07 AM
WannabeGT4 Couldn't you use the IDL signal from the TPS t... Jul 22, 2006 - 7:59 AM
presure2 Art,
great to see you tackle this project and wor... Jul 22, 2006 - 8:07 AM
lagos QUOTE(Dr_Tweak @ Jul 22, 2006 - 7:07... Jul 22, 2006 - 9:09 AM
WannabeGT4 Like I said use the IDL signal from the TPS to tri... Jul 22, 2006 - 9:26 AM
Dr_Tweak QUOTE(WannabeGT4 @ Jul 22, 2006 - 2... Jul 23, 2006 - 8:07 PM
lagos yeah, your right, that would probably be the best ... Jul 22, 2006 - 9:56 AM
lagos i thought of another simple way of doing this. th... Jul 22, 2006 - 5:29 PM
WannabeGT4 The whole purpose of the idle up VSV is to stabili... Jul 22, 2006 - 10:26 PM
lagos QUOTE(WannabeGT4 @ Jul 22, 2006 - 11... Jul 22, 2006 - 11:11 PM
lagos so here is an update....
i added in the AC idle ... Jul 29, 2006 - 8:33 PM
phattyduck QUOTE(lagos @ Jul 29, 2006 - 6:33 PM... Jul 30, 2006 - 2:57 PM
lagos QUOTE(phattyduck @ Jul 30, 2006 - 3... Jul 30, 2006 - 3:12 PM
malecrod Sorry to bring this back from the dead. I have a w... Mar 4, 2008 - 12:02 PM
lagos QUOTE(malecrod @ Mar 4, 2008 - 12:02... Mar 4, 2008 - 12:13 PM
malecrod QUOTE(lagos @ Mar 4, 2008 - 12:13 PM... Mar 4, 2008 - 7:31 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 11th, 2026 - 5:24 PM |
