Jul 20, 2006 - 3:12 PM
i just installed my turbo timer, and made it work along with my alarm. its so easy, that i cant belive some of us every thought of this as a problem.
first of all, there IS a turbo timer harness that works with our car! any harness labled to work with a 93-96 supra will work with our car. i used a blitz turbo timer, and this is the harness i got. if you want to doubble check if your are buying the right one (if going with another brand TT) just google something like "apexi turbo timer harness ST205 " and use the part number they give you for that harness. this is the one i used: TY-04 = BLITZ TURBO TIMER HARNESS - 51153 now for the "hard" part of making it work with your alarm. normally your alarm box connects to 2 wires from your igniton. located the point where it was spliced into your ignition wires. there should be a black Ignition wire its spliced into. disconnect the alarm wire that runs to it. this will make the alarm think that the car is NOT running, and allow you to arm the alarm system at any time. THATS IT. now you can take you keys out, get out of the car, arm the alarm, and walk away, while the turbo timer counts down on its own and keeps the engine running. This post has been edited by lagos: Jul 20, 2006 - 3:21 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
lagos How To install a turbo timer WITH your alarm Jul 20, 2006 - 3:12 PM
defgeph Wouldnt the vibration from the engine running or s... Jul 20, 2006 - 3:27 PM
lagos QUOTE(defgeph @ Jul 20, 2006 - 4:27 ... Jul 20, 2006 - 3:44 PM
defgeph Sweet, this will be a nice addition to the stickie... Jul 20, 2006 - 3:47 PM
phattyduck Wouldn't this remove the alarm's ability t... Jul 20, 2006 - 4:18 PM
lagos QUOTE(phattyduck @ Jul 20, 2006 - 5... Jul 20, 2006 - 7:06 PM
lagos there might be another simple way to do this also.... Jul 20, 2006 - 7:15 PM
x_itchy_b_x i just use the factory alarm adding a turbo timer ... Jul 20, 2006 - 7:18 PM
presure2 just to add somthing into this:
while researching ... Jul 22, 2006 - 8:14 AM
lagos QUOTE(presure2 @ Jul 22, 2006 - 9:14... Jul 22, 2006 - 9:42 AM
6strngs sorry to bring an old thread back to life, but I... Jan 14, 2008 - 9:13 PM
Batman722 with most alarms the "auto arm" is a fea... Jan 14, 2008 - 11:16 PM
6strngs QUOTE(Batman722 @ Jan 14, 2008 - 8:1... Jan 15, 2008 - 12:26 AM
Batman722 ok ok
it a clifford, now find out what model it is... Jan 15, 2008 - 12:42 AM
6strngs QUOTE(Batman722 @ Jan 14, 2008 - 9:4... Jan 15, 2008 - 11:19 AM
NuclearHappineS Is the problem with turbo timers the auto arm?
or... Jan 16, 2008 - 12:03 PM
vsideboy clifford make their own turbo timer that you can h... Jan 18, 2008 - 6:48 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 9:20 AM |
