3 Pages V   1 2 3 >
> Silicone Couplers and T-Bolt Clamps
post Jul 23, 2006 - 7:10 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Where are you guys getting your stuff?? I'm switching everything to black and have to get some more T-Bolt clamps also.......and need them quick. Any suggestions on where to check?
post Jul 23, 2006 - 7:18 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
roadraceengineering.com
coupling by the foot, and i just bought there regular hose clamps, you can tighten to 152 inch pounds, but they sell t-bolts too
This post has been edited by brianforster: Jul 23, 2006 - 7:18 PM
post Jul 23, 2006 - 7:52 PM
don't get regular worm clamps they are horrible and the "slots" get screwed up use T-bolt clamps
post Jul 23, 2006 - 7:53 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
wtf is a worm clamp? and have you ever used road race clamps? they are strong as hell..
theres no reason to overkill everything, ive yet to blow a clamp and i run my car hard as ****. ive bent my intercooler piping tightening down my clamps.
and *gasp* THEY ARENT T-BOLTS! OMG!
post Jul 23, 2006 - 8:31 PM
QUOTE(brianforster @ Jul 23, 2006 - 8:53 PM) [snapback]459937[/snapback]
rolleyes.gif its wat you have on your car...typical style screw clamp aka a worm clamp
quality and overkill are two different things make sure you can tell the difference..
just like a quality IC setup should have beaded ends of pipes, but most of us don't have those now do we...but its not overkill its just a quality job...
post Jul 23, 2006 - 9:03 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
I won't be using the screw clamps. I've had too many of those come apart when really trying to tighten down on something, and as of recently have had them chewing through in-tank fuel lined causing leaks. T-Bolt Clamps all the way for me.
post Jul 23, 2006 - 9:07 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE(Fastbird @ Jul 24, 2006 - 2:03 AM) [snapback]459963[/snapback]
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jul 23, 2006 - 9:27 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok nobody listen to what i have to say, but go ahead, spend 2x the amount on t-bolts, if it helps you sleep at night.
This post has been edited by brianforster: Jul 23, 2006 - 9:28 PM
post Jul 23, 2006 - 10:24 PM
QUOTE(brianforster @ Jul 23, 2006 - 10:27 PM) [snapback]459981[/snapback]
i had normal clamps on mine. for a while everything seemed ok, till one day my IC piping poped off on the highway and the car stalled out. it was the pipe right next to a super hot exhaust manifold. that was a lot of fun trying to fix and not get burned.
i got t-bolts and have never had a pipe come loose in the 2+yrs since ive had them . so, yeah ..get t-bolts. just dont over torque them of you have thin aluminum piping.
you can get everything you need from ebay. get the long tube that the sell by the foot on ebay. its the cheapest way to go, and you have the benefit of cutting the pieces as long as you want them to be. a 4foot tube should be enough.
post Jul 23, 2006 - 10:46 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
my worm clamps are rated at 150 inch pounds, i dare someone on this forum to prove to me that there clamps are rated at a higher torque.
post Jul 23, 2006 - 10:50 PM
these are the clamps brian likes:
and these are the t-bolts im using.
nuff said.
post Jul 23, 2006 - 10:54 PM
you like your lables way too much....stop sticking behind your 150 inch pound crap....worm style are PROVEN to be lesser quality then a T-bolt for obivous reasons...the thread on the screw or on the band can get messed up and not allow for full torquing of the clamp....i have already replaced 2 worm styles on my jetta because of this reason as well as fastbird already had an issue with worm style as has art...that makes 3 of us in a very small group of people
t-bolts will not deform the track/thread as does a worm this makes them more reliable...
but if we really really wanna get into this...then we should all invest into a set of WIGGINS clamps which cost over 100$ per clamp
http://www.burnsstainless.com/Hardware/Wig...ginsclamps.html
these are the clamps playr likes
This post has been edited by playr158: Jul 23, 2006 - 10:55 PM
post Jul 23, 2006 - 11:00 PM
i had a feeling someone was going to post those. umm yeah... they are a little bit of an over kill.... but just a bit.lol
post Jul 23, 2006 - 11:09 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
worm clamps are more likely to cut into the couplers as well.
post Jul 23, 2006 - 11:20 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
YOU CANT CLAIM THAT T-BOLT CLAMPS ARE BETTER THAN WORM CLAMPS AS A WHOLE, THERE CAN BE CHEAP T-BOLTS THAT ARE WORSE THAN EXPENSIVE WORM CLAMPS!
You talk about me hiding behind labels? you guys are all hiding behind the fact that it says "t-bolt" on your clamp, i think the real discussion should be what brands of clamps are good.
I certainly am going to stick with the fact that my worm style clamps are better and stronger than any of your cheapo ebay clamps.
ok im sorry if im out of line here but you all are being ridiculous, the original statement was to use t-bolt clamps because they are stronger and wont blow off under boost, but my clamps are rated at a higher torque specification than any one elses, yet you are STILL NITPICKING AT REASONS WHY T-BOLTS ARE BETTER, you show me numbers that prove that, and ill back down
This post has been edited by brianforster: Jul 23, 2006 - 11:21 PM
post Jul 23, 2006 - 11:22 PM
dont make me bust out the torque wrech...lol
i normally tighten mine down really tight with a 3/4th wrench. thats good for something like 10-30lb easy .
This post has been edited by lagos: Jul 23, 2006 - 11:23 PM
post Jul 23, 2006 - 11:25 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
please do, shut me up, i beg of you, but as of right now all im hearing is a bunch of people sit around and say "yep.. t-bolt clamps are better, cause they are called t-bolt, it doesnt matter what brand it is, just get the t-bolt.. t-bolt t-bolt t-bolt t-bolt.. by the all worm clamps suck, even if god forged a worm clamp himself, the 3.75$ ebay t-bolt will TROUNCE it in capabilities."
This post has been edited by brianforster: Jul 23, 2006 - 11:27 PM
post Jul 23, 2006 - 11:27 PM
QUOTE(brianforster @ Jul 24, 2006 - 12:25 AM) [snapback]460043[/snapback]
post Jul 23, 2006 - 11:30 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(brianforster @ Jul 23, 2006 - 11:25 PM) [snapback]460043[/snapback]
Time to have a beer Brian.
post Jul 23, 2006 - 11:59 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
i am just a little pissed that im the only person to give a specific link and quote an actual number yet the bandwagon comes along and completely disregards what i have to say and assume that t-bolts are godly.
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: August 29th, 2026 - 9:50 PM
