Jul 26, 2006 - 8:57 PM
Enthusiast ![]() Joined Jun 14, '06 Currently Offline Reputation: 0 (0%) |
So today, I'm driving around, like I usually do, and I hear a familar and unwanted clunking when I brake, as well as some higher pitched irregularly spaced noises.
I think my right rear wheel bearing is shot. Again. I replaced it a little over 1K ago, and the aforementioned noises were present before I did it, and magically disappeared after. My hope is that I'm just retarded, the bearing is fine, nothing's on the actual axle is loose, and I just need to replace my worn struts/sway bar bushing/something else not expensive. I jacked 'er up after I got home, wiggled the tires, sure enough, the right one's got a little play, and the left one's tight as <insert vulgar term here>. Any suggestions?? When I replaced it a month ago, I just bought a wheel bearing, and ended up paying almos the price difference of a wheel bearing vs bearing and hub assembly for a shop to press it. Shiza, I'm going to go punch a wall or something. -------------------- Andrew
1994 Black GT ![]() |
XCSkierFreak WHAT THE FARK?! Jul 26, 2006 - 8:57 PM
airfron buy a speed bag too drywall is expensive to replac... Jul 26, 2006 - 9:39 PM
XCSkierFreak Good idea. No need to be spending more money on s... Jul 26, 2006 - 10:19 PM
Bitter lowerball joint or tierod end can cause loosenes. ... Jul 26, 2006 - 10:21 PM
XCSkierFreak I'm going to take the whole tire/caliper/rotor... Jul 26, 2006 - 10:33 PM
LewFX check the strut Jul 27, 2006 - 10:32 AM
fastgt If the bearing is bad again you may have to replac... Jul 27, 2006 - 11:11 AM
XCSkierFreak I know the struts are more or less shot, but the n... Jul 27, 2006 - 2:49 PM
fastgt Thats what i did with my old celica...i replaced t... Jul 27, 2006 - 2:59 PM
XCSkierFreak Okay, here's what I know:
I called up a half ... Jul 27, 2006 - 9:41 PM
LewFX only way to get a hub and bearing for 80 bux if yo... Jul 27, 2006 - 10:36 PM
XCSkierFreak Now I know that I spose. I'd seen anywhere fr... Jul 27, 2006 - 10:41 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 9:16 AM |
