Jul 27, 2006 - 6:14 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
im getting the all too familiar sound of something rubbing as the car spins, now im assuming its the rear brakes since those are the only things ive done stuff to.
what could this be? on my SHO it was dragging because of a bad brake line but these rear brakes were super easy to bleed and the bleeding process was not painful at all, much better than the other times ive bled brakes. im thinking maybe the rotors are bad? they were not looking to hot when i put them on but i still put them on for budget reasons, i figured i had to atleast see if they were bad before replacing them. i dont however see how this could cause a dragging type noise coming from the rear. tomorrow im gonna go for a drive with my buddy in it so he can try and diagnose the sound with his head out the window or something. maybe its something as easy as the parking brake being too tight but when the car was up in the air i could spin both tires without hearing anything. |
Jul 27, 2006 - 6:26 PM
parking brake off? parking brake adjustment have enough slack? does the wheel spin freely when the car is off the ground? you may need to adjust the shoes in some.
Jul 27, 2006 - 6:55 PM
im gonna try that tomorrow, i just got too frustrated too today, should i be able to pull the ebrake handle all the way to the top?
Jul 29, 2006 - 1:35 AM
Enthusiast ![]() ![]() ![]() Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
Did you take the old proportioning valve off and replace it with one from a 4 disc-brake celica? IF not that is your problem. There is a constant pressure applied to the drum brakes from the proportioning valve..
-------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Jul 29, 2006 - 12:42 PM
Enthusiast ![]() Joined Jun 15, '06 From NJ Currently Offline Reputation: 1 (100%) |
if the rear wheels spin freely, see if the backing plate is touching the rotor. its very easy to bend them when doing brake work
Jul 30, 2006 - 4:14 PM
you don't need a 4disk proportioning valve it works fine with the stock piece..
make sure the e-brake adjuster is correctly adjusted (its behind the rotor) |
Aug 8, 2006 - 10:56 PM
Enthusiast ![]() ![]() Joined Jun 30, '05 From Chattanooga, TN Currently Offline Reputation: 5 (100%) |
had the same problem on my last car, like cheeco said i had bent the dust guard behind the rotor and it was rubbing
This post has been edited by Stu37363: Aug 8, 2006 - 10:57 PM |
Aug 10, 2006 - 8:51 PM
Enthusiast ![]() Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
QUOTE(Stu37363 @ Aug 8, 2006 - 10:56 PM) [snapback]466908[/snapback] had the same problem on my last car, like cheeco said i had bent the dust guard behind the rotor and it was rubbing i would check that first, i've seen that alot! and you don't need a new proportioning valve, it does'nt hold pressure on the drums and according the the specs the pressure difference is minimal. -------------------- ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 3:36 PM |
