Jul 28, 2006 - 4:27 PM
Enthusiast ![]() ![]() ![]() Joined Mar 6, '03 From South Central Los Angeles and Long Beach, CA Currently Offline Reputation: 1 (100%) |
Well pretty much just like the topic says, how do I get a JDM 6gc cluster 2 work on a USDM 6gc? I have Doggy's 1st model and its not working. I thought it was just bolt up, plug and play? Anything I'm missing? Or need to adapt? I thought I heard sum1 talk about it once, but I'm not sure.
I appreciate any help you can give me. Thanx, David |
Jul 28, 2006 - 4:30 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
http://www.6gc.net/forums/index.php?showtopic=30411
stickies roxz! This post has been edited by jdg371: Jul 28, 2006 - 4:30 PM |
Jul 28, 2006 - 6:55 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
If you've got a ST205 cluster you're trying to make work that sticky should work for you... If not, I can help you with getting the one you have working.
-------------------- ![]() Project ST204.5 99.88946% complete... |
Jul 28, 2006 - 9:36 PM
QUOTE(WannabeGT4 @ Jul 28, 2006 - 4:55 PM) [snapback]462638[/snapback] If you've got a ST205 cluster you're trying to make work that sticky should work for you... If not, I can help you with getting the one you have working. Yea, I was reading the sticky, but no I don't have the st205 cluster. I'm fault for not saying that. I need the st202 instructions, I believe. But if its the jdm at200, can u still get me that info. Thanks, David |
Jul 29, 2006 - 6:45 AM
I could help you if you took a good pic/scan of the circuit on the back of the cluster... As long as I can see exactly where all of the trace are going I can make it work. Label the bulb sockets and screw holes as to what the function is and then I can work out a conversion for your stock wiring.
This post has been edited by WannabeGT4: Jul 29, 2006 - 6:46 AM -------------------- ![]() Project ST204.5 99.88946% complete... |
| Lo-Fi Version | Time is now: August 4th, 2026 - 12:16 PM |
