Aug 2, 2006 - 8:24 PM
Enthusiast Joined Nov 30, '05 From 8o8 StAte (Hawaii) Currently Offline Reputation: 0 (0%) |
my car does not go into all the bottom gears 2,4,R could someone give me some suggesstions on what is wrong and how i go about fixing it
thanks |
Aug 2, 2006 - 9:06 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Long Beach Currently Offline Reputation: 1 (100%) |
im guessing its the shifter cables. check them.
-------------------- Is this good enuff 4 ya? :D
Aug 2, 2006 - 10:49 PM
Enthusiast ![]() ![]() ![]() Joined Jan 29, '06 From Kitchener, ON, CA Currently Offline Reputation: 0 (0%) |
either that or you need a new tranny
Aug 2, 2006 - 10:53 PM
Enthusiast ![]() ![]() Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
that happened to me when the "u" clamp came off my cables, so yeah... check that out
-------------------- ![]() The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Aug 4, 2006 - 8:49 AM
Im gunna say shifter cable, Pull out you'r shifter assemble, and look and make sure there is nothign blocking the cable from moving. Mine did the same thing.
Aug 10, 2006 - 11:00 PM
![]() Enthusiast ![]() Joined Dec 4, '04 From just moved from houston to austin Currently Offline Reputation: 0 (0%) |
shifter cables or your tranny's syncronizer.
-------------------- [SIZE=7][COLOR=blue][SIZE=1]-WES-
Aug 13, 2006 - 2:18 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 30, '03 From IL Currently Offline Reputation: 15 (100%) |
the fork thing in the shifter assembly that goes through your gears are bent maybe?
-------------------- PROJECT 6TH GEN
![]() <FS: Things up for grabs> <Progress> |
Aug 21, 2006 - 12:02 AM
Enthusiast ![]() ![]() Joined May 24, '03 From Andrews TX Currently Offline Reputation: 1 (100%) |
it was my shifter cables when it happenned to me, especially happenned when I tried to shift fast.
Got worse and then the U-clamps came off that held cables to linkage. what you can do is either have some one move the shifter and wath the cables to see if you have any excessive play, or put your car in gear and move to check for play -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
| Lo-Fi Version | Time is now: September 3rd, 2026 - 2:17 PM |
