> How much time to replace brakes?, front and rear
post Aug 4, 2006 - 9:53 AM
liquor
Joined Jan 31, '03
From Montreal, Canada
I need to have replaced all 4 discs + pads on my 94 GT. How long should it take to do this job?
post Aug 4, 2006 - 9:58 AM
jdg371
Joined Jun 14, '05
less than an hour.. have every tool needed and all the parts. dont forget the never sieze(sp)
If I remember corectly.. you need a 14, 17,8, vicegrip, partner (for bleeding the brakes)
This post has been edited by jdg371: Aug 4, 2006 - 9:59 AM
post Aug 5, 2006 - 12:53 PM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
I replaced both discs and pads in front and back. It took me about 1 1/2 hour.
Only pads shouldn't take much longer then 30 minutes
JDM ST205
post Aug 7, 2006 - 5:04 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
QUOTE(jdg371 @ Aug 4, 2006 - 3:58 PM) [snapback]465344[/snapback]
You should NOT have to bleed the brakes to change the discs/pads.
If all the bolts unfasten easily and you can get all the wheels off at the same time then about an hour, otherwise I would leave yourself 2hours + if you have to take wheels off individually and 3-4hours if you have to lube the bolts before unfastening them
post Aug 7, 2006 - 6:37 AM
gt4uk
Joined Sep 9, '04
From England
QUOTE(vsideboy @ Aug 7, 2006 - 11:04 AM) [snapback]466258[/snapback]
took me close to 1 day to replace the rear pads....wheels off, easy, peasy...2 pins that hold the pads in place were stuck fast, no amount of penetrating oil would budge them....ended up having to remove the calipers totally from the car..start with a small drill and work'd my way up to virtually drilling the pins out..then quick hammer with a punch got them out...replace, repete on the other side, then bleed the brakes...propper night mare...the pads hadnt been out in years, infact the pads were in japanese so i reccon a good 5 or 6 years since they were out...not fun at all...need someone to make me some of the pins in stainless steel..will stop the alloy/steel binding together...
post Aug 7, 2006 - 1:08 PM
creis
Joined Jan 10, '04
From Shoreline, WA
i'ed say set aside 2 hours, you'll probaby find yourself sitting down with a cold soda after 1 and a half though. just dont rush it.
post Aug 7, 2006 - 5:09 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
anyway u guys can set a how to on changin these?...im tempting to change all four pads + rotors..but kinda worried if i might f*ked somethin up.....
Lo-Fi Version Time is now: August 25th, 2026 - 4:37 PM
