Aug 9, 2006 - 9:55 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
Tuner Toys adapter came in today. Just got it hooked up after the wife came home from work with the car. Now my question.....
What's oil pressure supposed to be at for the 3S???? Right now it's at 10-20 PSI at idle and at 1500 RPM's it's come up to around 40 PSI, and on a free rev up to about 3500-4000 RPM the pressure comes up to about 58 PSI. The load (if you want to call an idle rev that) pressure responds for what I consider to be fine (approx 10 PSI per 1K rpm), but I'm left wondering if the idle pressure is low at all. Eighteen PSI at idle to me just isn't the best. Which leads me to this question: Obviously the oil pressure sending unit is on the head. But where on the head does it actually take the pressure reading from?? Is it a open area on the head with oil flowing around it or is it actually in an oil passage? Thanks guys. -------------------- |
Fastbird Oil Pressure Gauge Finally Working Aug 9, 2006 - 9:55 PM
alltracman78 It reads directly from the passage. The sender is ... Aug 9, 2006 - 10:02 PM
jgreening QUOTE(alltracman78 @ Aug 9, 2006 - 10... Aug 9, 2006 - 10:35 PM
lagos it takes the oil from an open area.
at idle you s... Aug 9, 2006 - 10:02 PM
alltracman78 QUOTE(lagos @ Aug 9, 2006 - 10:02 PM... Aug 10, 2006 - 6:47 PM
Fastbird Ok, looks like we're good then. The mofo was ... Aug 9, 2006 - 10:21 PM
lagos QUOTE(jgreening @ Aug 9, 2006 - 11:3... Aug 9, 2006 - 10:51 PM
Fastbird 68 PSI pressure on a cold start. 18-20 once warme... Aug 10, 2006 - 7:29 PM
lagos QUOTE(alltracman78 @ Aug 10, 2006 - 7... Aug 10, 2006 - 8:03 PM
Fastbird Whatever Doc put in it. Haven't hit the oil c... Aug 10, 2006 - 8:16 PM
Bitter QUOTE(Fastbird @ Aug 10, 2006 - 8:16... Aug 10, 2006 - 8:19 PM
Dr_Tweak Glad you got it going. Sounds like your oil pressu... Aug 10, 2006 - 10:00 PM
Bitter QUOTE(Dr_Tweak @ Aug 10, 2006 - 10:0... Aug 10, 2006 - 10:23 PM
Dr_Tweak QUOTE(Bitter @ Aug 11, 2006 - 3:23 A... Aug 11, 2006 - 11:09 AM
alltracman78 QUOTE(Dr_Tweak @ Aug 11, 2006 - 11:0... Aug 11, 2006 - 8:04 PM
Bitter QUOTE(alltracman78 @ Aug 11, 2006 - 8... Aug 12, 2006 - 8:53 AM
Fastbird QUOTE(Bitter @ Aug 12, 2006 - 9:53 A... Aug 12, 2006 - 9:17 AM
Bitter i didnt know the turbo wasnt oil'd, that makes... Aug 11, 2006 - 11:36 AM
Dr_Tweak QUOTE(Bitter @ Aug 11, 2006 - 4:36 P... Aug 11, 2006 - 2:08 PM
Fastbird QUOTE(Dr_Tweak @ Aug 11, 2006 - 3:08... Aug 11, 2006 - 7:29 PM
Fastbird I'm sticking with dino oil because I'm a f... Aug 11, 2006 - 12:10 PM
hitcachi QUOTE(Fastbird @ Aug 11, 2006 - 12:1... Aug 11, 2006 - 12:16 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 28th, 2026 - 12:33 AM |
