Aug 18, 2006 - 6:00 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
Of all the tools in my garage and room, this tool kiked a55!
![]() YES! It's your Trust-Worthy PiPe used for levrage, hitting, smashing wasps, transfering liquids, hammer and even a weapon. Def, a must have in your car! |
Aug 18, 2006 - 6:20 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 16, '04 From Baton Rouge, LA Currently Offline Reputation: 0 (0%) |
That Dan guy is pretty much a tool.
Aug 18, 2006 - 6:46 PM
8mm, 10mm, 12mm, 14mm, 18mm, 22mm sockets
grease rags patience and of course a This post has been edited by LewFX: Aug 18, 2006 - 6:48 PM -------------------- ![]() |
Aug 18, 2006 - 8:10 PM
Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
Dont buy cheap tools...they are a complete waste of money and you`ll just end up loosing skin off your knuckles when they slip or break.
dont forget a 36mm socket for the crank pully a crank puller wire brush timing gun compression tester lithium grease brake bleeding kit volt tester inspection mirror trolley jack (the most expensive you can afford) axel stands x4 2x10" extension bars for 1/2" drive socket set rubber mallet lots of WD40 circlip pliers. |
Aug 18, 2006 - 9:47 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
QUOTE(Insanity-74 @ Aug 18, 2006 - 8:10 PM) [snapback]470427[/snapback] dont forget a 36mm socket for the crank pully Good Lord. What engine is that for? A 700 CI desiel? S series crank pulleys should be 21mm. Or possibly 19. But I believe it's 21. -------------------- ![]() |
Aug 19, 2006 - 3:02 PM
Doh...dont know what I was thinking when I typed that, I meant to say 36mm socket for the wheel hub nuts
Aug 19, 2006 - 4:22 PM
Hubs should be 30mm.......
Aug 20, 2006 - 2:04 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
12 point are very good to have & to pull head blots (4age) the most un common tool is the axle size socket ...
Aug 20, 2006 - 8:11 AM
mighty vac.
for ANY type of brake or clutch or whatever bleeding, its THE tool to have. also good for vacume tests. -------------------- Former Team 5SFTE pro member ;)
Aug 20, 2006 - 9:06 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
I'm going to retract a previous statement. I mentioned about getting a 1/2" torque wrench and a reversible 3/8" to 1/2" adapter. Scratch the adapter. I snapped my second one in as many months yesterday. First time I tried to use it too. Just get a set of 1/2" extensions and be happy, and pick up the 1/2" sockets while you're at it.
Aug 20, 2006 - 9:13 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
my 1/2 to 3/8 adapter has a liftetime hasslefree warranty (loews, kobalt tools) one of the best things ive ever purchased.. so convenient because my tool set didnt come wiht ANY 1/2 extentions.
thread locker, high temp rtv, and pb blaster are overlooked as well.. those are something you should have plenty of.. a breaker bar, and of course a 6 pack. ive seriously tackled almost every bolt on my car with my 119 piece kobalt tool set.. i think ive had to buy a 24mm and a 27mm socket, a 1/2-3/8 adapter, and a universal joint. This post has been edited by brianforster: Aug 20, 2006 - 9:15 AM |
Aug 20, 2006 - 11:34 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) |
All this advice is great guys. I am taking it all into consideration!
Aug 20, 2006 - 11:41 AM
universal joints are great. they really help you get into those tight places with less hassle
| Lo-Fi Version | Time is now: September 3rd, 2026 - 12:33 PM |
