> BOV with recirc options
post Aug 16, 2006 - 1:20 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok two questions, i need a cheap and easy recirc valve cause i dont really mind not having the cool sound, and id rather my car run as smoothly as possible..
my friend got one from forge motorsports, he really likes it, my question is whats the easiest and cheapest way to attatch a valve like this? get a piece of straight pipe and have a nipple pressed in? then connect the nipple to the BOV with a hose?
im also thinking about the greddy rs, a little more expensive though.
the stock BPV would be nice too but i dont think theres a clean and easy way to get that to work with my FMIC piping.
Replies (1 - 9)
post Aug 16, 2006 - 2:05 PM
WALKER
Joined Mar 29, '06
From Regina, SK, Canada
Does the celica actually run smoother with a recirculation? Just am curious, because I thought on a MAP car it wouldn't make any difference.
post Aug 16, 2006 - 2:06 PM
forge is good...its a diverter valve...i personally recommend the Forge 007 DV
and yes basically take a piece of your intercooler pipe and have a 1" diameter pipe about 2" long welded onto it to make a "T"
you can clamp a hose to that "T" and then to the diverter valve..and then do the same T thing for your intake hose and run a hose from the DV to teh intake..
and he has a 3sgte motor which is AFM/MAF 2nd gen..
This post has been edited by playr158: Aug 16, 2006 - 2:07 PM
post Aug 16, 2006 - 2:08 PM
hitcachi
Joined Jun 19, '05
From Nebraska
Also, if u want some more info or a good example, talk to Jay here on the site. He can tell you quite a bit about it too.
post Aug 16, 2006 - 3:33 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Brian,
I've got one that would be perfect for you, it's a Bosch turbo bypass valve, basically the same thing you'd find on a Porche Turbo. It had a 1" inlet and outlet, so it's very easy to recirculate. In fact, all you have to do is drill and tap a 1" hose barb onto the intake charge pipe, one onto the turbo inlet pipe, and then connect the two 1" hoses.
It's $75 shipped.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Aug 16, 2006 - 3:41 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ill get back to you doc, in the meantime can you get me a pic?
post Aug 16, 2006 - 3:45 PM
WALKER
Joined Mar 29, '06
QUOTE(playr158 @ Aug 16, 2006 - 1:06 PM) [snapback]469655[/snapback]
Ah yes he does, sorry I must have been having one of those moments.
post Aug 19, 2006 - 9:15 AM
Dr_Tweak
Joined Mar 31, '04
QUOTE(brianforster @ Aug 16, 2006 - 8:41 PM) [snapback]469693[/snapback]
post Aug 19, 2006 - 11:19 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I think most cars with re-circ valves actually perform a lot better than just having a blow-off valve. Because in theory the boost escapes into the air with a BOV, but if you have a re-circ it also goes back into the turbo so the boost is there. If you have both it's even better since 1 can protect the turbo from ova boost and yet have that power.
post Aug 19, 2006 - 2:06 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
i ended up winning a forge motorsports 007 off of ebay, thanks anyway doc..
now if the guy would just respond.. hes got 79 positive feedback but hasnt messaged me back in like 3 days frown.gif
Lo-Fi Version Time is now: August 11th, 2026 - 9:39 PM
