> Eck, urgent help work in the morning, high idle with new intake
post Aug 17, 2006 - 11:01 PM
Vissi
Joined Jun 6, '06
From Cedar Hill ,Texas
I jsut instlled my short ram on the car (temporary), and right after WOT, the idle gets realy high, the first time it was at 2k and the secound it was at 3k.
Its realy freakin me out, i have both of the extra breather thingies capped off, and the air sensor in pluggd in.I just got an oil change but idk if that could cause anything like this.
I would love any suggestions, thanks
-dave
0111011001101001011100110111001101101001
Chrome wont get ya home
post Aug 18, 2006 - 1:13 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Sounds like you got a leak...
post Aug 18, 2006 - 1:22 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
You occasionally need to reset the ECU when changing from a Panel Filter to a CAI. If you take the ECU fuse out thats in the box in the engine bay for 15mins then I think that does it.
I'm sure someone will confirm this. I did it to mine when I put mine on but didn't need to do it when I swapped the filters back again.
post Aug 18, 2006 - 1:24 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(vsideboy @ Aug 18, 2006 - 6:22 AM) [snapback]470167[/snapback]
I still say leak... =P
post Aug 18, 2006 - 1:25 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
leak where?
i've run mine without the airfilter pipe connected for a brief period and it idles normally.
post Aug 18, 2006 - 1:27 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(vsideboy @ Aug 18, 2006 - 6:25 AM) [snapback]470170[/snapback]
leak where?
The reason for the big idle change is more than likely a leak on the intake. The ECU doesn't affect idle as much as 2000-3000 rpms due to a minor change like a short ram...
post Aug 18, 2006 - 10:02 AM
Vissi
Joined Jun 6, '06
hmm, i think there may be a small leak around the air sensor. What could i use to fill it?
-dave
post Aug 18, 2006 - 10:52 AM
Vissi
Joined Jun 6, '06
hmm, i taped off those breather ports on it, i dont think i had the small one closed right. and i had em hooked together.
My idle is back down, and man when that manfold opens up it gets loud. I love the sound!
Lo-Fi Version Time is now: June 13th, 2026 - 1:00 PM
