Aug 19, 2006 - 3:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
Pre-install:
Before recieveing the intake I had decided I was going to replace the filter. Appon receiving it I was glad I had gotten a new one. ![]() ^filter I recieved ![]() ![]() ^filter I replaced it with After attaching the filter, I attached the Rubber Coupler to the intake. ![]() ^intake just prior to install The install: I first removed the upper air intake tubing, and filter box. The tubing is connect to the throttle body by a clamp, and to the filter box by another clamp. (sorry I didnt take pictures of it) The filter box itself is attached to the body of the car by 3 bolts, 2 inside the filter box, and one on the outside, located between the filter box and the strut tower. (again sorry I didnt take pictures of it) ![]() ^what I removed, (top airbox with filter, and tubing from the throttle body. I plan to remove the lower airbox later on this week. [the one in the fender]) ![]() ^what the engine bay looks like with the upper OEM intake stuff removed. I attached the intake with a 2" Rubber Coupler from Lowes ($3.47 in the plumbing section, near the pvc piping) ![]() My first problem was this: ![]() ^hole for the temp sensor ![]() ^the temp sensor The whole is to large, the answer. Grommet ![]() ^advanced auto parts, got a set of a whole bunch of sizes for $3.xx (i used the size that fit the temp sensor, the outside diameter was slightly smaller then the Injen's hole, so I wrapped a rubber band to make it larger for the time being) Next issue was: The intake has connections for the pcv and another hose, but the OEM hoses are to narrow in the interior diameter, to me directly attached to the intake. So I left the pcv hose connected to the throttle body, and had it bypass the intake all together. I went back out to advanced autoparts, and got some Vac Caps. ![]() ^and example of one. ![]() ^example of where it goes (there was 2 places i caped, the other is on the underside of the induction tube) Final Product: ![]() ![]() ![]() Build total: Injen SRI: $80 Shipped From Zipstrips (again I would like to state that he is an awsome seller) K&N Highflow Cone Filter: $60 From Advanced Autoparts Rubber Coupler: $3.97 From Lowes Set of Vac Caps: $3.xx From Advance Autoparts Set of Grommets: $3.xx From Advance Autoparts Total: $149.97 PS: THANK YOU TO LAGOS and MYNZEYES FOR HELPING ME NOT LOOSE MY COOL WHEN STUFF DIDN'T FIT RIGHT AWAY. This post has been edited by devilsden97: Aug 19, 2006 - 3:10 PM -------------------- ![]() Kawi Love |
Aug 19, 2006 - 3:13 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
Lagos and Mynzeyes helping FTW.
and btw, that's an odd cap. i was thinking about the kind that goes OVER the nipple sticking out...not into it...neat though. and those rubber bands were hardcore ghetto. haha. -------------------- |
Aug 19, 2006 - 10:16 PM
you forgot the stock reservior under the car?
Aug 19, 2006 - 10:22 PM
QUOTE(LewFX @ Aug 19, 2006 - 11:16 PM) [snapback]470715[/snapback] you forgot the stock reservior under the car? "(top airbox with filter, and tubing from the throttle body. I plan to remove the lower airbox later on this week. [the one in the fender])" -------------------- ![]() Kawi Love |
Aug 20, 2006 - 12:19 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
Rubber bands in gromet = 1337!
This post has been edited by hitcachi: Aug 20, 2006 - 12:19 AM -------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Aug 20, 2006 - 12:43 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) |
Great job. Nice write up with good pics!
One thing I have noticed now is that the '94 & '95 models don't have a vacuum line directly into the intake, only into the throttle body. When we install these SRI on our engines, should we look at putting a vacuum line into the intake, or is bypassing that and only having the vacuum into the throttle body best? -------------------- |
Aug 20, 2006 - 10:31 AM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
thanks again..
and if u look in the stock black piping, our grommit for the air sensor could have been pulled from there |
Aug 21, 2006 - 8:13 PM
QUOTE(zipstrips @ Aug 20, 2006 - 11:31 AM) [snapback]470827[/snapback] thanks again.. and if u look in the stock black piping, our grommit for the air sensor could have been pulled from there i did that about 10 minutes go....woot woot, no more rubber bands -------------------- ![]() Kawi Love |
Dec 19, 2008 - 11:09 PM
Enthusiast ![]() Joined Jun 5, '08 Currently Offline Reputation: 0 (0%) |
hey so is the temperature sensor the one on the top airbox with the filter? i noticed there's a connection there but i'm not sure wat it is or wat to do with it..
Dec 19, 2008 - 11:18 PM
Theres one more hole in the piping near the throttle body.
| Lo-Fi Version | Time is now: September 12th, 2026 - 11:53 AM |
