> 4age big port head = small port intake or custom, (for the 7agte) Nik, fallenhero or kwanza for this one .
post Aug 20, 2006 - 9:44 AM
frotou
Joined Jan 9, '04
From Quebec city, Quebec, Canada
What difference can be noticed on a turbochaged big port head with the big port vs small port vs custom intake manifold ?
Thanks for help.
Claude
Replies (1 - 4)
post Aug 22, 2006 - 9:52 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(frotou @ Aug 20, 2006 - 2:44 PM) [snapback]470819[/snapback]
Bigport has bigger ports, which can potentially make more power (depends on boost levels, turbo/trim, and tuning). Bigport and smallport are about equal boosted. Smallport has the added advantage of being workable, ie: porting and reshaping whereas the bigport isn't (ports are too big to make a lick of a difference). Smallport will have a stronger mid-range versus a bigport without TVIS. The main thing... boost is the equalizer. In n/a form, I'd say smallport all the way...
As far as intake manifolds go... depends on what you mean by custom.
post Aug 23, 2006 - 12:55 AM
frotou
Joined Jan 9, '04
I mean by custom intake manifold ; a bigger square aluminium box with four bigger runner coupled with a 3" throttle body. (we can see some example on club4ag).
Thanks for help.
Claude
post Aug 23, 2006 - 2:32 PM
nik
Joined Sep 30, '02
QUOTE(frotou @ Aug 22, 2006 - 10:55 PM) [snapback]471855[/snapback]
Thanks for help.
Claude
i looked around alot on club4ag go look at there tech section it talks aout the big port and small port
post Aug 24, 2006 - 11:40 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(frotou @ Aug 23, 2006 - 5:55 AM) [snapback]471855[/snapback]
Thanks for help.
Claude
You misunderstood my question... but heheh... ok. A custom intake manifold performs relative to the engine. If you're talking a higher volume manifold... you can potentially make more power... but that's assuming a stock manifold is restricting your set-up. There are a LOT of things to consider when talking about custom intake manifolds... something I don't want to get into right now... =/ Let's just say it depends on what's pushing air through that manifold.
Lo-Fi Version Time is now: August 28th, 2026 - 7:51 AM
