Aug 20, 2006 - 1:26 PM
![]() Enthusiast ![]() Joined Jun 27, '06 From South Lake Tahoe Currently Offline Reputation: 0 (0%) |
Hey all,
Fall is just arownd the corner and I was thnking I would disconnect the a/c and try to free up some more of the little engine power i have with the 7afe. Is the best way just to take off the belt? Would It even be worth it? If any one has done it i would love some pointers. thnx, SpooNr -------------------- ![]() |
Aug 20, 2006 - 1:36 PM
Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
QUOTE(SpoonR530 @ Aug 20, 2006 - 1:26 PM) [snapback]470869[/snapback] Hey all, Fall is just arownd the corner and I was thnking I would disconnect the a/c and try to free up some more of the little engine power i have with the 7afe. Is the best way just to take off the belt? Would It even be worth it? If any one has done it i would love some pointers. thnx, SpooNr No, it would not make even a bit of difference. -------------------- ![]() |
Aug 20, 2006 - 1:39 PM
It worked in a 87 bmw 318 why wouldnt it make a difference in a celica, less stress on the engine ...?
Aug 20, 2006 - 1:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
are you wanting to take the compressor off and everything? or just "disconnect it". bc if you want to take the compressor off, you will be needing a new belt..also, it's just as fine to just not run the A/C when you want the "extra power"...
Aug 20, 2006 - 1:55 PM
The 7afe is considered a underpowered engine, and if you remove the belt you won't notice any dramatic change in performance. Also, to ensure that your car's a/c system doesn't mess up you'll have to run your a/c at least once a month. So it would be pointless to keep putting your belt on and off every month just to make sure you a/c still works. And another thing, you'll still have to put another belt for your alternator.
Aug 20, 2006 - 1:59 PM
When we did it in my friend beemer we took the whole thing out. I cant remmeber if we put in a new a belt or not. After, we could definitely feel the difference between when the A/C was OFF and when we took out the whole unit. Neways I could take out the comp but i was wonder if i could short cut that and get the same bennies. If not, I would love to hear from someone who has acctually done it.
This post has been edited by SpoonR530: Aug 20, 2006 - 2:17 PM -------------------- ![]() |
Aug 20, 2006 - 2:20 PM
QUOTE(SpoonR530 @ Aug 20, 2006 - 11:59 AM) [snapback]470878[/snapback] When we did it in my friend beemer we took the whole thing out. I cant remmeber if we put in a new a belt or not. After we could definitely feel the difference between when the A/C was OFF and when we took out the whole unit. Neways I could take out the comp but i was wonder if i could short cut that and get the same bennies. If not, I would love to hear from someone who has acctually done it. Your friend's Bimmer probably uses a different sort of A/C compressor. Ours use a clutch of some sort, so that the pulley pretty much spins freely when the A/C isn't turned on, meaning that the drag on the pulley and crankshaft from the A/C compressor when it's not on is very, very minimal. I'm pretty sure you wouldn't notice a difference, unless you actually removed the A/C components, and then, that difference would be because of weight reduction, not decreased drag on the motor. -------------------- New Toyota project coming soon...
Aug 20, 2006 - 2:44 PM
Hm..... IC. I suppose ill just go with the pully and reduce the friction that way to the other accesories. Tnx for the advice all, and saving me a couple useless hours messin with the ac.
This post has been edited by SpoonR530: Aug 20, 2006 - 2:47 PM -------------------- ![]() |
| Lo-Fi Version | Time is now: June 12th, 2026 - 7:13 PM |
