> boost controller broken?, greddy profec spec B
post Aug 22, 2006 - 3:49 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok so today i finally got around to installin' my boost controller.
It is hooked up as so:
We used the nipple to the VERY right of the intake manifold. It was blocked off up until this point. I made sure it was indeed a vacuum port by blowing in it and air went through the intake system.
This hose is hooked up directly to the profec's headunit.
We hooked up the solenoid as so:
"IN"is hooked up from the compressor housing, and "out" is going to the wastegate. The other port on the wastegate (the one for the factory boost controler?(TDIS brian says)) is not hooked up.
THis is not Brianforster, this is his buddy so I apologize, but I dont know everything about how your silly turbos work.
At first, we were getting good boost playing with the knobs and making good pressure. We would hit 15 psi, and then it would slowly lose pressure till about 12 or 13. We played more until but we couldn't get any more out of it(still peaking at 15 and dropping). Then, it stopped working. It would make the factory 7-8 and nothing more. We parked it, checked our connections and hoses, and drove it again. It worked for the first two pulls, but afterwards, same stock boost.
I have two thoughts on this problem. One is that maybe I hooked up the solenioid backwards, I will go check.
Two, should the wastegate get the compressor housing pressure and then we hook the soleoid "in" to another port and the "out" to the blocked off hose on the wastegate, or is it all just broken?
TY
- brianforster   boost controller broken?   Aug 22, 2006 - 3:49 PM
- - brianforster   ok for the record i told him the other hose was fo...   Aug 22, 2006 - 4:46 PM
- - zipstrips   sounds all too familar..... im looking forward to ...   Aug 22, 2006 - 5:03 PM
- - lagos   QUOTEThe other port on the wastegate (the one for ...   Aug 22, 2006 - 5:46 PM
- - brianforster   yes that line is plugged, dip switches are correct...   Aug 22, 2006 - 5:48 PM
- - lagos   no. the charcol canister one is not a good source ...   Aug 22, 2006 - 5:50 PM
- - brianforster   i tapped in to the map sensor hose for my line tha...   Aug 22, 2006 - 7:02 PM
|- - zipstrips   QUOTE(brianforster @ Aug 22, 2006 - 5...   Aug 22, 2006 - 11:44 PM
- - brianforster   zipstrips have you ever hit more htan 4psi on your...   Aug 23, 2006 - 12:38 AM
|- - zipstrips   QUOTE(brianforster @ Aug 22, 2006 - 10...   Aug 23, 2006 - 6:44 AM
- - brianforster   im pretty sure you have to unplug the tvsvconnecto...   Aug 23, 2006 - 9:02 AM
|- - zipstrips   QUOTE(brianforster @ Aug 23, 2006 - 7...   Aug 23, 2006 - 1:43 PM
- - lagos   tvis = toyoa variable induction system. this is o...   Aug 23, 2006 - 1:57 PM
|- - zipstrips   QUOTE(lagos @ Aug 23, 2006 - 11:57 A...   Aug 23, 2006 - 2:00 PM
- - lagos   whats your vac like at idle? did you ever try to ...   Aug 23, 2006 - 2:03 PM
- - brianforster   today it worked for a bit again, i was in the midd...   Aug 23, 2006 - 3:31 PM
- - zipstrips   any progress brian?   Aug 27, 2006 - 4:50 PM
- - brianforster   well halfway up to my trip to college i decided to...   Aug 28, 2006 - 12:31 AM
- - zipstrips   ive been doing some reading and researching in som...   Aug 28, 2006 - 1:39 AM
Lo-Fi Version Time is now: August 31st, 2026 - 12:46 AM
