Aug 23, 2006 - 1:29 PM
Enthusiast Joined Aug 14, '06 Currently Offline Reputation: 0 (0%) |
1997 GT Convertible, my LED break light bar does not work althoug the LED brake light in the spoiler works. is it supposed to work with the spoiler or is it one or the other? I have not taken the trunk lining apart yet to see if the wiring is disconnected figured i ask some enthusiast first. Any ideas?
Aug 23, 2006 - 1:41 PM
Enthusiast ![]() Joined Dec 20, '04 From oc, california Currently Offline Reputation: 0 (0%) |
Test the wiring with a cheap test light from autozone. If it works replace the bulb.
Aug 23, 2006 - 3:19 PM
QUOTE(calicelica @ Aug 23, 2006 - 1:41 PM) [snapback]472040[/snapback] Test the wiring with a cheap test light from autozone. If it works replace the bulb. thanks...we'll do. it is supposed to work with the spoiler LED break light isn't it? |
Aug 24, 2006 - 6:09 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
if it isnt already then you will be able to wire it in parallel with the other bar. normally led lights are made so that if one blows then the others remain working so i would guess that its not plugged in or its just come disconnected inside the bootlid.
| Lo-Fi Version | Time is now: August 23rd, 2026 - 4:20 PM |
