> OBD1 HELP! CEL, *UPDATED* VIDEO CLIP
post Aug 26, 2006 - 8:09 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
Guys, I need help asap. My Celica has had a check engine light for a while now but I will be driving 4 hours for a Celica meet on Friday and need the Celi in tip-top shape. I don't want it to blow up halfway there.
When the key is in the ignition, the check engine light and battery light come on (i have a brand new battery in the car). I diagnosed my check engine light. It blinks twice, then pauses, then blinks once. Here's a video of it:
Can someone please tell me what this means, what code or whatever?
Thanks!
This post has been edited by JoKeRkId613: Aug 26, 2006 - 10:19 PM
post Aug 26, 2006 - 8:53 PM
FlamingCelica
Joined Apr 16, '06
From Jackson, MS
The friday before last my check engine light came on, took it to the toyota dealership today and it was just the oxygen sensor that plugs into the exhaust pipe before the cat, funny thing is that we already knew the line was broken from it and it showed no check engine light, it took it almost a year to recognize it. Other than that if it runs smooth and cranks its probably just a o2 sensor, but im not sure about where you can get it checked out, unless theres a dealer near you. biggrin.gif
~FlamingCelica
This post has been edited by FlamingCelica: Aug 26, 2006 - 8:55 PM
94 Red Celica ST
post Aug 26, 2006 - 9:41 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
bump
post Aug 26, 2006 - 9:56 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
This is from the Chilton manual. Trouble code 21: "Oxygen Sensor signal, oxygen sensor signal voltage is reduced to between .35 V and .70 V for 60 sec. under conditions (a)-(d).
a.) Engine coolant temp.: 176 degrees F or more
b.) Engine speed: 1,500 rpm or more
c.) Load driving (Ex. A/T in overdrive ( 5th forM/T). A/C on, Flat road, 50mph
d.) oxygen sensor signal voltage Alternating above and below .45V
Not real sure what it means, but that's straight out of the book.
post Aug 26, 2006 - 10:07 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
hmmm... thanks. i was thinking it was code 21. does it tell u how to fix it? im guessing buy a new oxygen sensor? lol. well, im going to try to find an owners manual online and see if it tells me anything different. thanks man.
EDIT: yup, just checked the good ol' toyota manual.
Code 21 - Defective O2 Sensor, Open or Short Circuit in O2 Sensor Signal
DAMN P.O.S. O2 sensor! lol. anyone know how to fix this? ah, i guess i'll search. lol. thanks.
This post has been edited by JoKeRkId613: Aug 26, 2006 - 10:22 PM
post Aug 26, 2006 - 11:00 PM
try reseting the ECU first. Sometimes there will be a "false" reading.
post Aug 27, 2006 - 1:01 AM
take a look at your o2 sensor and make sure its pluged in and the wiringd dosnt look damaged. then reset the ecu and see if the code comes back. if it does, replace the o2 sensor.
post Aug 27, 2006 - 11:10 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
how do i reset the ecu? is it the one in the how-to with the removal of some fuses?
post Aug 27, 2006 - 12:22 PM
hitcachi
Joined Jun 19, '05
From Nebraska
yep ^
post Aug 27, 2006 - 2:00 PM
to reset the ecu, you just disconnect the battery for 30sec or so. you can also just pull out your efi fuse and do it that way, if you dont feel like having to reprogram your clock and stuff.
Lo-Fi Version Time is now: July 12th, 2026 - 4:58 AM
