Aug 28, 2006 - 6:18 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
For those who have not been reading.
The V6 swap has been done This project started in october 2005 when I finaly narrowed down what I wanted for the Celica. My options were either the famous relatively easy 3rd gen 3SGTE swap or the blind path of the V6. Before I begin, I owe a big thanks to all the MR2OC guys that helped me out. I was maybe alone in the garage but I had their support at all time. Big thanks to Adrian (aka: SbCelica on MR2OC). He pioneered the FIRST V6 Celica, a 5th gen celica with a 1MZFE. He was who inspired me to start the project. I followed in his foot steps. Research took from october to april and even continued on as I made my progress. I spent a good two months gathering parts and getting everything ready for the big swap. Often reading myself to sleeping with a pile of toyota wiring diagrams in my bed. Here's how I made it happen My setup: 04 Sienna 3MZFE -150amp Alternator -Solara power steering (sienna pump doesn't fit) -Toyota Matrix K&N intake (thats right, a Matrix intake fits) -Fidanza 1MZFE Flywheel -3SGTE clutch 01 Solara E153 Transmission -Alltrac rear and driver side mount, GT front mount -GT-FOUR shifter cables -MR2 turbo (non LSD) inner axles -Solara axle carrier -ST185 outter axles (with abs cause I have it) -ST185 speed sensor I don't know where to start, to me it's all self explainatory. Without going into deep details, heres a few pointers. The engine fits very well inside the engine bay, no clearance issue at all. It's narrower than the 5SFE and less in a slant so the rear is easily accessed. It fits better than a 5SFE basicly. The hood is a minor issue, it closes just fine but it's so close it's scary. The whole front bank (head) touches the insulation of the hood. The cure is a GT-four hood and we all know it needs a GT-four bumper aswell. I have that up on the upgrade list. Wiring isn't hard ! You all get that out of your head It's very time consuming tho, preparation was the key. On paper it took me months to prepare it bit per bit but it took me about 10 hours to physicaly do it. Keep in mind that this is for the most electronicly advanced V6 swap (next to the still unexploited 2GRFE). The ECU controls the automatic transmission so it needs to be fooled into thinking there is one by putting resistors where it seeks the transmission coils. I haven't got around to perfecting that. This engine uses a returnless fuel system, basicly a ordinary fuel pump with the regulator inside the tank. I adapted this system by swaping out my 5SFE pump for a sienna pump (bolt on, plug and play), hacked off a section off the steel return line next to the pump, strapped on the regulator and Tee-d the main line to the return line on top of the fuel pump cap. Gas pedal, no longer. It's now a accelerator position sensor. AKA drive by wire. no more throttle cable, no more cruize control servo and computer. it's fully electronicly controlled by the ECU now. Immobilizer - I have two keys now, one for my ignition and one with a chip in it to satisfy my immobilizer so it'll let me start my engine. I had to get the coil amplifer (basicly the ring around the ignition) and the immobilizer computer ("immobilizer" is an annoying word to type) Mounts, those are a piece of cake. 3 mounts are on the transmission, I swapped out for a E153 Solara V6 transmission. More on that later. I used alltrac rear and driver side mounts. The rear had to have a spacer because the cross member had a slant in it and the mount would have sat on an angle. The driver side had to be grinded down a bit to fit because it was too large to fit in the frame bracket. The front is my old GT stock. The passenger side one had to be custom made, I simply took out the mounting bracket and made one that fit for the V6. Personaly I don't like this but it works and doesn't seem to cause any problems. I will be making a whole new mount for it using a spare driver side mount. The stock strut bar fits but interferes with the engine rocking back and forth so I took it out and will be making a custom strut bar. I didn't notice any change in handling. Transmission, as I said before, I am using a 01 Solara E-153. I had to get a speed sensor, shifter cable mounting bracket and levers (thank you bigal Axles, I used non-lsd mr2 turbo inner axles (because I don't have LSD) ST185 outer ABS axles (because I have ABS) and a Solara V6 axle carrier. Fit right into place but I still have to get a spacer for the passenger side axle. it works tho Exhaust - the nightmare Nothing fit, not the front nor the rear headers fit. I did a simple cut, flange, route job to my stock exhaust for the moment. At this time I ran out of funds and could not afford a full exhaust. I will be making custom headers for this baby, 2.5" front to back, magnaflow muffler. Radiator hoses are a mess, the outlet and inlet are at opposite side of the radiator. The overflow tank needs to be Tee'd because I now have two fill caps. One on the engine and one on the rad. EVAP system, I got a EVAP canister from an Echo and stuck it on the opposite side of the muffler at the rear. Drilled a hole in the fuel tank, just in front of the fuel pump cap and stuck a check fill valve. This isn't necessary unless you want to get rid of the check engine light (and codes). Or live in a place that have strict emission guidelines. anyone from cali? and more but I can't think of anything else right now. To this day, even if it runs, I don't concider it complete. I have some bugs to work out and some minor refinements. Towards the end, I was broke and I needed to rush things because I was starting a new job and needed a car so I did the bare minimum. Now I'm too busy working and paying off debts, lol but I'm not giving up. Winter is coming, things will settle and I will perfect it. I am hoping that the V6 swap becomes mainstream. It's not that hard to do and can be done for less than a 3SGTE. Please don't argue this before researching the prices. My swap was a full drivetrain swap, it would have been much simpler if I would have stuck with the GT tranny and I would have cost much much less. But the Solara tranny is far better than the GT tranny and is optimal for this engine.... at a price. There is also the 1MZFE which is easier than the 3MZ, less wiring, less gizmos (no drive by wire, no immobilizer, fewer o2 sensors, etc... just simpler) Well thats all I want to say for now, I have to take a break from typing so much. Too many PMs to reply too on top of this. Hope you found it interesting -------------------- ----------------------6GC's FIRST V6----------------------
![]() JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
K-ESD The V6 Celica is here Aug 28, 2006 - 6:18 PM
celica47 Hey man congrats...your a PIONEER...iam really int... Aug 28, 2006 - 6:21 PM
K-ESD I must add, the information above is for a 3MZFE
M... Aug 28, 2006 - 6:23 PM
HaRv3sTeR props Nick!
hope to go back in Moncton soon ... Aug 28, 2006 - 6:31 PM
94_st_hatchback GET SOME VIDS!!! Aug 28, 2006 - 6:31 PM
coldbluesteel Congrats, I want to be the first to use the 5vz... Aug 28, 2006 - 6:39 PM
WALKER Good work, glad to hear its working for you!
... Aug 28, 2006 - 6:59 PM
jdg371 QUOTE(WALKER @ Aug 28, 2006 - 7:59 P... Aug 29, 2006 - 12:04 PM
Punch a vid would be great... Aug 29, 2006 - 10:38 AM
lagos PICS!!!!!!!!!... Aug 29, 2006 - 11:06 AM
hitcachi i demand pictures! Aug 29, 2006 - 11:33 AM
bindertch QUOTE(coldbluesteel @ Aug 28, 2006 - 4... Aug 29, 2006 - 2:09 PM
twolownissan2002 pic would would be nice great work bro Aug 29, 2006 - 2:13 PM
WH95TE Very Very nice, I too want to see pics and videos ... Aug 29, 2006 - 2:20 PM
celicurr what everyone else said... nice, but we need pics ... Aug 29, 2006 - 5:01 PM
Shigexile so it actually happened...
congrats man congrats.... Aug 29, 2006 - 5:21 PM
K-ESD Thanks everyone
It was the biggest project I... Aug 29, 2006 - 5:49 PM
bloodrain QUOTE(K-ESD @ Aug 29, 2006 - 6... Aug 29, 2006 - 6:51 PM
illneversellmycelli Iwant to know the pirce of it all vs the 3g, i wan... Aug 29, 2006 - 6:28 PM
6th_celi_vert you've inspired me.
Im gonna drop a 454 in m... Aug 29, 2006 - 6:36 PM
toyotacrazy QUOTE(6th_celi_vert @ Aug 29, 2006 - 6... Jan 25, 2007 - 9:03 PM
LBCxGUY just wanted to know ur driving impressions on the ... Aug 29, 2006 - 6:49 PM
K-ESD QUOTE(bloodrain @ Aug 29, 2006 - 8:5... Aug 29, 2006 - 8:59 PM
K-ESD QUOTE(illneversellmycelli @ Aug 29, 2006 ... Aug 29, 2006 - 9:14 PM
soulshadow hmmmm, the 3mzfe off of the sienna is pretty fast.... Aug 30, 2006 - 12:02 AM
Punisher What bracket did you use in the rear? I also had t... Aug 30, 2006 - 12:36 AM
K-ESD QUOTE(Punisher @ Aug 30, 2006 - 2:36... Aug 30, 2006 - 5:32 AM
HaRv3sTeR vids!!! Aug 30, 2006 - 6:31 AM
jess_i_74 So cool to hear this, K-ESD. Thanks for being a pi... Aug 30, 2006 - 7:26 PM
K-ESD QUOTE(jess_i_74 @ Aug 30, 2006 - 9:2... Aug 30, 2006 - 8:12 PM
toyotatech for those of you wanting to try this with the 1mz ... Aug 30, 2006 - 10:02 PM
Bitter looks like those may have been from a floaded/tota... Aug 30, 2006 - 10:15 PM
toyotatech QUOTE(Bitter @ Aug 30, 2006 - 10:15 ... Aug 30, 2006 - 10:36 PM
K-ESD QUOTE(toyotatech @ Aug 31, 2006 - 12... Aug 31, 2006 - 5:54 AM
j0e_p3t if you ever decide to move to southern california.... Sep 2, 2006 - 2:06 AM
hitcachi any videos or sounds clips yet... Sep 2, 2006 - 1:18 PM
azian_advanced congrats K-ESD.. that's one big step for the ... Sep 2, 2006 - 6:35 PM
Bitter v6gc.net Sep 2, 2006 - 8:29 PM
DeathWing dyno! Sep 3, 2006 - 12:21 AM
K-ESD about the vids, picts, sound clips, other entertai... Sep 4, 2006 - 4:00 PM
HaRv3sTeR QUOTE(K-ESD @ Sep 4, 2006 - 9:0... Sep 4, 2006 - 5:13 PM
fastgt QUOTE(jdg371 @ Aug 29, 2006 - 10:04 ... Sep 6, 2006 - 11:18 AM
SinisterWhisper 2GRFE is simply too costly at this point for most ... Sep 6, 2006 - 3:47 PM
jdg371 For the 3MZ you grab all the computers needed to g... Sep 6, 2006 - 4:46 PM
K-ESD QUOTE(jdg371 @ Sep 6, 2006 - 6:46 PM... Sep 6, 2006 - 6:06 PM
K-ESD QUOTE(SinisterWhisper @ Sep 6, 2006 - 5... Sep 6, 2006 - 6:16 PM
K-ESD and the update
the celica is back in the garage f... Sep 6, 2006 - 7:05 PM
spolski07 i love it!!! Sep 6, 2006 - 7:13 PM
hitcachi +1 sticky this work of art! Sep 6, 2006 - 8:59 PM
Valo666 dude..drive to ontario, and do this for my car..ho... Sep 7, 2006 - 11:31 AM
celica47 IAm really interested also.... i mean 200+ HP n/a ... Sep 7, 2006 - 12:54 PM
K-ESD sorry, I won't be making any swaps for others.... Sep 7, 2006 - 5:39 PM
ThAixGuYx2k7 You are incredible man. WAY TO GO! You have al... Sep 7, 2006 - 7:20 PM
zipstrips congrats on your work! Sep 7, 2006 - 10:27 PM
K-ESD QUOTE(ThAixGuYx2k7 @ Sep 7, 2006 - 9... Sep 8, 2006 - 5:42 AM
Rayme I'm cheap, maybe a low-mileage 3vz-fe iin the ... Sep 8, 2006 - 5:50 AM
3rdgen3SGTE belle job c'est pas un anglophone qui aurais f... Oct 2, 2006 - 12:51 PM
Shigexile QUOTE(3rdgen3SGTE @ Oct 2, 2006 - 12... Oct 2, 2006 - 1:16 PM
94celicadude ce boulot a etait vraiment bien fait. Great job ma... Oct 2, 2006 - 2:11 PM
K-ESD QUOTE(3rdgen3SGTE @ Oct 2, 2006 - 2... Oct 2, 2006 - 3:14 PM
azian_advanced je parle français aussi, peux-tu m'installer u... Oct 3, 2006 - 1:12 AM
K-ESD rel (rire en ligne)
désoler, je n'installera... Oct 3, 2006 - 6:05 AM
Rayme QUOTE(K-ESD @ Oct 3, 2006 - 8:0... Oct 3, 2006 - 9:06 AM
celica47 i feel like iam missing out on something..... Oct 3, 2006 - 10:44 AM
GTSOwner QUOTE(celica47 @ Oct 3, 2006 - 10:44... Jan 25, 2007 - 10:59 PM
fastgt QUOTE(celica47 @ Oct 3, 2006 - 8:44 ... Oct 3, 2006 - 1:00 PM
celica47 lol i know its french, did you translate there con... Oct 3, 2006 - 1:04 PM
fastgt na too lazy Oct 5, 2006 - 8:34 AM
Jeremy1210 QUOTE(fastgt @ Oct 5, 2006 - 9:34 AM... Oct 5, 2006 - 9:45 AM
hashmaster52 vids or anything yet??? Jan 25, 2007 - 1:28 AM
Haven I have been wondering if a v6 swap would even be p... Jan 30, 2007 - 4:51 PM
3rdgen3SGTE ya tu des nouvelles photo...new pics? Aug 26, 2007 - 11:29 PM
K-ESD oui, les nouvelle picts on ete poster la semaine p... Aug 27, 2007 - 6:07 AM
KB-2 can we please stop the french nonsense....maybe? Aug 27, 2007 - 11:31 PM
K-ESD QUOTE(KB-2 @ Aug 28, 2007 - 1:3... Aug 28, 2007 - 3:57 PM
Jlacker3 This reminds me of this...
The Ballad of Ricky Bo... Aug 28, 2007 - 7:39 PM
99GT Any updates? Dyno numbers? Nov 14, 2007 - 11:57 AM
playr158 ricky bobby FTW Nov 14, 2007 - 12:19 PM
K-ESD update: Rayme HID/Projector retrofit done, parked ... Nov 14, 2007 - 3:01 PM
illneversellmycelli how is the aftermarket support fpr the 3mzfe? i co... Nov 19, 2007 - 11:32 PM
joehernandez QUOTE(K-ESD @ Nov 14, 2007 - 3... Nov 20, 2007 - 3:29 PM
K-ESD illneversellmyceli:
There are piston/rods cams, va... Nov 20, 2007 - 5:12 PM
illneversellmycelli appreicate it k-esd, ill def doo sum research on t... Nov 21, 2007 - 1:37 AM
Fuzzy Did you install the custom strut bar? Have any pic... Nov 21, 2007 - 2:56 PM
K-ESD I haven't got around to making the strut bar y... Nov 22, 2007 - 5:21 PM
daazndood so what are the estimated 0-60 and 1/4mile times? Nov 24, 2007 - 5:30 AM
njccmd2002 do you have a picture of the custom passenger moun... Aug 30, 2009 - 12:13 PM
stephen_lee QUOTE (njccmd2002 @ Aug 30, 2009 - 11... Mar 1, 2010 - 6:33 PM
match220 Anyone done this while wiring in an EMS? I have an... Aug 30, 2010 - 11:19 PM
stephen_lee im going to run mega squirt on my 3vz Sep 1, 2010 - 7:06 PM
match220 QUOTE (stephen_lee @ Sep 1, 2010 - 2... Sep 6, 2010 - 3:27 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 29th, 2026 - 7:00 AM |
